2 motors same set of problems! help!
Old Jun 18, 2004 | 10:13 PM
johnzm's Avatar
Default 2 motors same set of problems! help!
motor #1
CTR pistons in a b18c bored to 81.5 honda rings
all seals in head replaced
fully balanced and broken in on c12 only, along with a wideband to moniter a/f
after first 20 miles started smoking. got worse and worse only when doing one specific thing-coasting down in gear then punching the gas. big blue smoke cloud out the back
motor #2
b18c bored to 81.5 pr3 pistons. hastings rings
head was left stock
fully balanced and broken in on 93 only
after 100 miles notices smoke out thetailpipe during the same conditions as motor #1. this motor was setup by a different person and was machined at a different machine shop. its at 400 miles now, and looking like its getting worse, just like motor number1
the only difference i can see so far is that motor #2 is holding ~530 vaccum at a warm idle where motor#1 was holding ~430 at idle
motor#1 was found to have a blow headgasket later, showing compression results of 290,230,225,240 with the bad headgasket in place still
can somebody please put an end to all these "guesses" about how the oil is getting out and provide some detail as to why its happening
Old Jun 19, 2004 | 02:28 AM
Joseph Davis's Avatar
Default Re: 2 motors same set of problems! help! (johnzm)
What was the final ignition timing on engine 1?
How did you guys break in the engines? Easy or hard?
Old Jun 19, 2004 | 08:43 AM
Drew96EJ's Avatar
Default Re: 2 motors same set of problems! help! (J. Davis)
both motors had a hard break in
the final ignition timing on motor#1 was ~18 degreeson c12
Old Jun 19, 2004 | 12:04 PM
Dual Cams's Avatar
Default Re: 2 motors same set of problems! help! (drew96EJ)
what are the clearance on the walls to piston?
Old Jun 19, 2004 | 07:13 PM
Drew96EJ's Avatar
Default Re: 2 motors same set of problems! help! (Dual Cams)
both were measured and within spec iam not sure of hte second motor but mine was on the fat side of spec(motor#1)
Old Jun 20, 2004 | 11:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drew96EJ &raquo;</TD></TR><TR><TD CLASS="quote">both motors had a hard break in
That's pretty retarded, and on high octane racegas. FInal timing in the stock ECU is 28 degrees, and the c12 means you should advance the timing a bit more added CR nonwithstanding. I think you ran the cylinders lean, regardless of how the wideband lied to you, because you were blowing still burning fuel/air past the exhaust valve with that ignition timing.
Old Jun 21, 2004 | 03:31 AM
Chiovnidca's Avatar
Anything done to the heads?
DaFredsta
Northern California (Sales)
23
Apr 22, 2010 09:24 PM
dailyekhatch
Nov 22, 2009 07:35 AM
Collateral
Mar 14, 2005 10:39 PM
drvfast
Jan 6, 2005 06:37 PM
Honda Kustums
14
Aug 27, 2003 07:33 AM
