Integra Type R Rear wing dimensions ? 94-01 Please help!!!
Old Jun 18, 2004 | 08:51 PM
ewen0010's Avatar
Default Integra Type R Rear wing dimensions ? 94-01 Please help!!!
I have purchased a honda integra Type R rear wing off a 1999 Type R integra under the assumption that it would fit my 1994 honda integra. However, once I recieved it, the wing bolt length (bolt-to-bolt) was one inch more than the width of my boot.
As you can understand I am quite upset and am in the process of returning it.
Can anyone please help me with the dimensions of a Type R spoiler (bult-to-bult) or even boot width???
My 1994 integra boot width is about 46 and a half inches.
Old Jun 18, 2004 | 09:29 PM
Mr.Fairlady's Avatar
Default Re: Integra Type R Rear wing dimensions ? 94-01 Please help!!! (ewen0010)
JDm 99 Integra?
well,..sounds like your holes need to be opened more/an Inch is alot,..but they all FIT....I mean,..there should be no probs,.unless its like warped????
94,99 all the same as far as trunk goes.Did yours have the Stock spoiler from factory,or,did you drill it?? then it should fit perfectly,..unless you have a GSR,..then 1 of your holes(2 on driver side & 3 on pass) will be peeking through where the Brake light harness goes(pass side),.but only a little bit.Enough for water to get up in there I know
Its Really hard to mess up drilling the holes(if you did it yourself) becasue they are Marked on the underside of the trunk lid.
Drilled my holes out(no stock spoiler) on my RSX-S for a Replica ITR Spoiler and it fit perfect,..and that was A damn Replica.
more details please
Old Jun 18, 2004 | 10:05 PM
KOALA YUMMIES's Avatar
Default Re: Integra Type R Rear wing dimensions ? 94-01 Please help!!! (Mr.Fairlady)
It could be a 4-door ITR wing if it is "jdm".
Old Jun 19, 2004 | 06:45 AM
Padawan's Avatar
Darth ModerVader
2 door Integra Type R wing...
Approximate distance between front bolts: 45-1/4"
Approximate distance between rear bolts: 44-3/4"
Old Jun 19, 2004 | 08:38 PM
ewen0010's Avatar
Default Re: Integra Type R Rear wing dimensions ? 94-01 Please help!!! (Padawan)
Thanks, that sounds about right. cool.
So does anyone have any idea what this spoiler could be for? It definately looks Type R style.
Old Jun 20, 2004 | 12:37 AM
Chiller's Avatar
It could be the accord type R wing. The wing looks exactly the same as the ITR one.
wannarace07
Northeast (Sales)
Feb 13, 2007 09:25 PM
slowacura
Nov 12, 2002 01:14 PM
Skunk_it
Oct 10, 2002 08:29 PM
