d15b with multiport running VERY rich
d15b with milled a6 head and multiport from d16a6 currently running pg7 ECU. pr4 and pg7 both tried and it is running rich as hell. also, the milled a6 head made the cam timing advanced 1/2 tooth, could that be the cause?
yes, if you mill the head the high compression change can definately affect your ful supply and/or fuel timing and pressure, i had that problem too once
i used a tps connector from my jdm b16 harness so it just plugged in and i had to match up the colors. i knew about switching the colors but i didnt because i had the right connector. what should the order be??
How much did you mill? Only enough to get it flat???
I doubt it's the mill job
If anything the PG7 runs rich even with the stock D16A6
Both those ecus are going to make your car run rich. I'd get the pr4 chipped if I were you, with the pm6 maps. Running rich has nothing to do with anything mechanically in your case.
I had the same problem when I had the MPFI swap wired. Turns out I wired the crank angle sensor incorrectly, had wires backwards, so two injectors were throwing LARGE amounts of fuel. Lucky my engine didn't screw up. Maybe distributor wiring?
ok, umm i just checked for codes. there is one blink , then a pause. then there are nine fast blinks and it repeats itself over. what does this mean? i looked in the faq and still couldnt figure it out.
Modified by drewthomas14 at 7:48 PM 6/20/2004
o2 sensor and CYP Sensor. Replace your o2 sensor and check your wiring on the distributor. If its not the wiring then you need a new distributor.
the o2 sensor woudl go bad because of it running so rich , right? i'll try another dizzy from a crx si and use his pm6 ecu too. thanks guys.
I told you why you're running rich. It's your ECU. I've ran both of them on a ZC and they were both rich, and that engine has need for more fuel than yours. Fix your error codes, then get a better ECU or get your pr4 chipped.
nope. i had a pr4 with pm6 maps in there. so ill assume a pm6 wont do much. zc ecu will make it run rich, but it wont blow out crazy smoke. the only difference between pm6 / pg7 / pm7 / pr4 are minor timing and fuel curves.
Jet Black
Nov 25, 2006 06:49 PM
CivicRaping
May 4, 2005 11:52 PM
