Amps Turning On, But No BASS, Rcas Wrong? *DETAILED*
First Ill name off my system
2 Audiobahn AW1206T 12" subs inverted
2 Clarion DPX 1000.2 Amps bridged @ 2ohm
Blaupunkt CD50 Deck
So Im installing my stereo into my 2nd Crx today and I dont know whats going on.
The amps turn on fine during both ignition and when the car is on but Im getting no bass so I think the rca's arent transferring the signal or I didnt hook them up right
Coming off of my deck there is a harness with 4 rca style connectors with about 6 inches of wire between the connectors and the deck. I THINK 2 were black and 2 were grey, but I remember them being labelled LF/RF/RR/LR , both amps are getting there own set of RCAS because they dont have the 4 holes to connect them.
Are these wires Im talking about even supposed to be for the rcas? There was also a blue/white wire that I used for the remote and it turns the amps on so I thought for sure those were for the rcas because there in the same little clip
Any help appreciated, Im gonna stay home tonight to help hide some wires and be close to the computer so I can make any adjustments
thanks
Blaupunkt CD50 Deck
thanks
Heres the specs on the deck
40 Watts (Max.) x 4-Ch, & including 4-Ch Low Impedance Preamp Output @ 4V
Codem Tuner
18FM / 12AM Preset Stations Including Travelstore Presets
Electronic Flip-Down & Detachable Faceplate
Blaupunkt's Exclusive BP-4 CD Deck with 3-Beam Holographic Laser Pickup & 1-Bit/8X Oversampling Digital Filter
Digital Clock & Yellow-Red-Blue Illumination
DMS CD Changer Controller Provides Mix 1& 2, Repeat, & Scan
Menu Options Including: Confirmation Beep, 6-loudness Levels, Adj. Scan Time, Radio Monitor On/Off Adjustable Turn-on Volume, Seek Sens Adj., STM, 12/24 Hr Clock
Optional IR Thummer Steering Wheel Remote
DIN/ISO Mounting
Controls Optional CDC A08, CDC A071, & IDC A09 CD Changers
DigiCeiver Codem D All-Digital Tuner including RDS & Sharx™ Adaptive IF Switching
Digitally Processed AM Noise Reduction
Selectable FM Hi-Cut Filtering
5-band Digital Parametric Equalizer
Telephone Audio In
CD Naming
2- Aux Inputs (CDC plus CC/MD/MP3)
Silver Faceplate Design Concept with Multicolor LCD
Digital EQ with Preprogrammed Settings For; Pop, Rock, Jazz, Classic, Techno & Speech
Selectable Car Acoustics Compensating Presets For; Roadster, 4-Dr, Convertible, Van, Compact Car, & Truck
Subwoofer Output
GALA (Speed Dependent Volume Compensation)
Codem Tuner
DIN/ISO Mounting
Telephone Audio In
CD Naming
Subwoofer Output
Ya there not even the same brand, one is a stinger 14 foot, and the other set I got from radioshack (free) when I got my second amp by surprise
Is the wires Im talking about deifnetley the RCA's though? BEcause thats the only thing I can think of being the rcas and the specs says 2 UAX impouts, meanins RCAS right?
Yup had the same problem like a month ago and never got it figured out and I decided to make that car my track car being as it already had the nice motor and I didnt wanna ruin it with my 9 cube box, thats why I said 2nd crx, this ones gonna be the "show" crx
BUmp
BUmp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">Yup had the same problem like a month ago and never got it figured out and I decided to make that car my track car being as it already had the nice motor and I didnt wanna ruin it with my 9 cube box, thats why I said 2nd crx, this ones gonna be the "show" crx
BUmp</TD></TR></TABLE>
some pics of the connections would help a lot.
and its exactly the same equipment? sounds like the radio to me
it's a yellow clip with with all the rca's and remote-turn-on right?
it should only plug into one place and yeah it should be the right ones, --this will sound ignorant---you do have the rca's plugged into the input of the amp, and not the output right? -- don't mean to sound rude...
There is only and imput on the amps, liked there is only 1 set of red/yellow on each amp, there isnt a second set so you can connect them like Ive seen on some
Ill get a pic
Ill get a pic
Yeah, the red and white "red/yellow" should be your inputs, on the cd- it should be a yellow plug for the outputs, just watchout 'cuz that radio does have inputs which could be in rca form, but according to your spec sheet you have sub output, so make sure it's both on and turned up, should be a setting in the menu or audio section...... pics from the back of the radio might be helpful...
I probably just have everything wired wrong and mixed up
Is a certain color coming off the deck supposed to connect to a certain color on the deck? the then from the rcas to the amp?
MAYBE YOUR RADIO HAS SUBwoofer on 'off'
like my alpine did that to me i had the sub amp plugged in but no signal held down the eject button and it said 'subwoofer on' and BASS was alive!
Why the eject button? Hmm guess I gotta bust out the manual, never even thought about that myself
Doesnt seem to be a high dollar deck though so I dunno if it would have that feature
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StealthEF »</TD></TR><TR><TD CLASS="quote">Why the eject button? Hmm guess I gotta bust out the manual, never even thought about that myself
Doesnt seem to be a high dollar deck though so I dunno if it would have that feature</TD></TR></TABLE>
thats what my alpine uses to turn on and off the subwoofer
it would probably be different on oither decks
and my alpine has 3 outs one for sub, doubt yoiurs would have the feature if it only has 2 or one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foz »</TD></TR><TR><TD CLASS="quote">not all alpine's work through the eject button -- side note -- other's have to go through the setup menu
i know, i didn't say all did just using mine as an example
WOT has a blaupunkt anyway
I dont think there was a sub on/off option in my menu
Is there something esle it could be called, I couldnt go to the car today because Ive been studying for a calculus exam tomorrow
