easy one for you guys.
I just got the ES master kit for my 90 civic, and i cant figure out where the "front strut rod bushings" go there is four of them and no instructions.
thank you
thank you
At the top of the front shock rod. The top one can be seen under the hood on top of the strut tower with the bolt that holds the strut in the mount. The other one goes right under it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsi »</TD></TR><TR><TD CLASS="quote">At the top of the front shock rod. The top one can be seen under the hood on top of the strut tower with the bolt that holds the strut in the mount. The other one goes right under it.</TD></TR></TABLE>
the es ones are about 1/4 inch bigger and 2x as thick...deffinatly dont go there.
the ones you said they were are the front stock bushings
Modified by Hybrid Hatchback at 9:34 PM 6/22/2004
red97civic
11
Jan 10, 2007 07:15 PM
Achenar
Suspension & Brakes
13
Aug 1, 2005 12:55 PM
