O2 sensor for a ZC
Old Jun 18, 2004 | 05:33 PM
Drake's Avatar
Default O2 sensor for a ZC
I have a question about the O2 sensor for my zc. Well my buddy hooked me up with a aftermarket header. But the O2 bung is on the downpipe right before the collector right. Well what im wanting to know is can i extend the wire on my O2 sensor?? I have heard that the length of the wire on the o2 sensor is what gives it resistance and if it isnt hte same length it will screw things up. Thanks in advance for the help guys.
Jeramy
Old Jun 18, 2004 | 06:08 PM
crxgator's Avatar
Default Re: O2 sensor for a ZC (Drake)
i extended mine and its been fine, no CEL, or worse a/f ratio, still getting the same MPG as before the extention...
Old Jun 19, 2004 | 01:49 AM
Drake's Avatar
Alright thank you very much Gator. Looks like ill be putting my downpipe on tommrow then. Thanks agian you all have a great day.
Jeramy
Old Jun 19, 2004 | 07:54 AM
91civicDXdude's Avatar
make sure you correctly strip, solder, and heat shrink all connections. Make the extension wire as short as possible.
Old Jun 19, 2004 | 08:36 AM
4potnick's Avatar
I didn't have to extend mine at all. I just spliced the wire harness, since the wire from the o2 runs toward the rear anyways. Pretty simple: cut harness wraping and run wire straight down to bung.
Old Jun 19, 2004 | 09:06 AM
crxgator's Avatar
Default Re: O2 sensor for a ZC (4potnick)
what i should have said was i made an extention wire...took an old o2 sensor clip and an o2 clip from a wiring harness i had, ran wire and solder'd the two together...pretty nice since it can be easily removed...
Old Jun 19, 2004 | 09:22 AM
4potnick's Avatar
Default Re: O2 sensor for a ZC (crxgator)
Did you have to cut the wire? The way I do it involves no wire cutting.
Old Jun 19, 2004 | 09:26 AM
crxgator's Avatar
none, i used the two clips and bought some wire at the store and put it all together...plug and play with any 88-91 crx/civic...
BLJ-93eg
Apr 27, 2007 02:03 PM
