please help quick, or god will kill kittens. (CAMBER KIT QUESTION)
Old Jun 18, 2004 | 03:14 PM
chihuahuamanx's Avatar
Default please help quick, or god will kill kittens. (CAMBER KIT QUESTION)
hey all, i just got my camber kit in, and boy does it look different from the camber kits ive put on my friends cars for them. it looks like it replaces the balljoint in the upper control arm. heres a link to the pic.
http://cgi.ebay.com/ebaymotors...=WDVW
i cant seem to get the mounts for the upper balljoint out (not sure if theyre even supposed to come out) my chiltons guide says that I have to replace the whole control arm when installing the upper balljoints. WTH?! HELP!!
Old Jun 18, 2004 | 04:15 PM
Default Re: please help quick, or god will kill kittens. (chihuahuamanx)
bump
Old Jun 18, 2004 | 04:35 PM
99_SH's Avatar
There are only two bolts holding the upper control arm in place. After those bolts are removed, the control arm slides right out. Press out the stock balljoints using a shop press, and install the new adjustable balljoints(camber kit). Its trivial, I dont see the issue here.
Also, the shop manual states to replace the control arm, because honda does not sell balljoints as a seperate piece; they come only with the control arm assembly.
Old Jun 18, 2004 | 04:41 PM
Default Re: please help quick, or god will kill kittens. (99_SH)
yea its a stupid question, i know. the reason i didnt know what was going on was the arm was so covered with that cardirt junk that it looked like it was welded on.
i dont have a shop press, will a mallet and some patience work?
Old Jun 18, 2004 | 06:05 PM
99_SH's Avatar
Ya, people have used the BFH(big fckn hammer) technique, and the balljoint does eventually pop out. Just hit the balljoint right dead on, you dont want to bend the control arm accidentally.
What I did was goto a local mechanic shop, and they pressed out the balljoints for $10 bux. Its not worth the effort. Autozone also rents out a balljoint press tool you can do with your hand(like a c-clamp with adapters).
good luck.
ub3rn00ber
Jan 12, 2011 09:12 AM
stefanne3
Apr 11, 2007 06:57 PM
down_the_hatch
10
Feb 17, 2005 06:40 AM
Steve90HB
Sep 4, 2003 12:47 PM
