6 psi Turbo charging a d16a6
Old Jun 18, 2004 | 02:42 PM
LankorDie's Avatar
Loved
Community Favorite
Default 6 psi Turbo charging a d16a6
I heard that if you have a 6psi turbo or less you will not need a intercooler is this true? If so would it be worth puting in my d16a6?
Old Jun 18, 2004 | 02:58 PM
4drEF's Avatar
Keyboard Humorist
Default Re: 6 psi Turbo charging a d16a6 (LankorDie)
Yes you can do that.
The Greddy kit is offered with or without the IC.
YES - it would be worth it!
Put an IC on later - colder charge is better than warm.
Old Jun 18, 2004 | 03:29 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: 6 psi Turbo charging a d16a6 (4drEF)
If I'm getting a smaller turbo, about how much would this hole set up run me?
What turbo should I get?
Old Jun 18, 2004 | 03:42 PM
shawn_crx's Avatar
Depend what is your goal.
Cheap Junkyard turbo going to be around 500-800.
Old Jun 18, 2004 | 03:48 PM
Gant's Avatar
Default Re: 6 psi Turbo charging a d16a6 (shawn_crx)
im throwing a d16z6 in my hatchback i already got the motor lined up and im gonna run the greddy turbo kit non intercooled at 6psi, its 1400 for the turbo kit
http://www.thezcr.com/html/greddyturbo.php
theres the site that shows u how to put the 92-95 civic greddy turbo kit in a Ef basicly the only part thats a pain is cutting a lil square off the crossmember cause the pipes hang a lil low (charge)
Old Jun 18, 2004 | 04:23 PM
Bogus Hatch's Avatar
Im sorry but i think the greddy kit sucks...u get no power out of it...all d series motors run slow as hell...do urself a favor...and this will save u the 1500 bucks that would spend on a **** greddy kit....go to johnnyracecar.com for the front mount...go to a speed shop near u see if they have any used turbos...or if they have any that might be blown....if it is blow u can have it rebuilt for 250 bucks or so...buy a rev-hard manifold...and purchase the needed intercooler piping , bov, and waste gate...total kit shouldnt run u more then 900 bucks...and it will allow much more flow and hp then that garbage greddy kit...here is why people think the greddy kit is good...its "reliable" yea thats great and everything...but "fast" is alot differnt then reliable...
Old Jun 18, 2004 | 04:26 PM
Gant's Avatar
Default Re: 6 psi Turbo charging a d16a6 (Bogus Hatch)
gr8 opinon but im still sticking to greddy thanx bye
Old Jun 18, 2004 | 04:44 PM
96-EJ6 B18C's Avatar
Default Re: 6 psi Turbo charging a d16a6 (Ba4)
I don't think the GReddy kit a a bad option, but don't expect huge numbers fom it. I'm in the middle of fabing my piping right now and I'm having a blast. It's really fun buying everything piece by piece the stacking the **** in your room for months while you save $. Then throwing it all in is really rewarding. I would (and did) build my own system, but the option is yours. Either way, one more boosted Honda
Old Jun 18, 2004 | 07:26 PM
johnclaunch's Avatar
I have a friend that did this whole job (baby Mitsubishi 6psi turbo, piping, blowoff valve, HF header) for $250 and a few hours of time. Why would anyone pay $1500 for a little 6 psi turbo setup? You could buy a better engine and swap parts for that. This turbo setup is meant to be a cheap upgrade. A way to get a 60 hp increase quick. 70 stock hp (Civic STD) + 60 hp (cheap turbo setup) = 130 hp. A B16 swap would get you 160 hp. Not to mention it would be a DOHC good motor instead of an SOHC Economy D-Series turd motor. The turbo setup is a good idea for someone with an under-performing Honda wanting to spice it up a bit. It is not some awesome SPANK-YOUR-STUPID-CAMARO-SS-***-CAUSE-I-GOT-A-TURBO-HONDA thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn_crx &raquo;</TD></TR><TR><TD CLASS="quote">
Cheap Junkyard turbo going to be around 500-800.</TD></TR></TABLE>
What the hell junkyard is this? 5-8 hundred for a used ****-hole turbo!!??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bogus Hatch &raquo;</TD></TR><TR><TD CLASS="quote">...go to a speed shop near u see if they have any used turbos...or if they have any that might be blown....if it is blow u can have it rebuilt for 250 bucks or so...buy a rev-hard manifold...and purchase the needed intercooler piping , bov, and waste gate...total kit shouldnt run u more then 900 bucks...</TD></TR></TABLE>
Again, 900 bucks? ZC motor swap for the same amount.
Go spend $1400 on a baby turbo setup. You will still get beat by V-8s, Integras, and even '94 Si's. I wish I had $1400 in pocket change to throw away. Hell, you could go buy a whole 91 Civic for $1400.
Old Jun 18, 2004 | 08:57 PM
91civicDXdude's Avatar
i spent about $900 on my turbo setup. It will blow the ******* doors off of a ZC swap "for the same amount". It will blow the doors off of a b16 swap, b18c swap, LSVTEC swap, and whatever gay setup you have.
biatch.
ported HF manifold, adapter plate, 14B turbo, oil lines... $125
comp 59300 cam.... $250
front mount intercooler.....$130
blow off valve... $50
91 PM6....$30
Batronix ROM burner....$80
EEPROMS & ZIF socket..$30
apex'i VAFC...$100
DSM 450cc injectors...$30
various charge piping and connectors...$50
AutoMeter gauges and pillar....$200
Old Jun 18, 2004 | 09:56 PM
Nature's Renewal's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">i spent about $900 on my turbo setup. It will blow the ******* doors off of a ZC swap "for the same amount". It will blow the doors off of a b16 swap, b18c swap, LSVTEC swap, and whatever gay setup you have.
biatch.
91 PM6....$30
apex'i VAFC...$100
AutoMeter gauges and pillar....$200</TD></TR></TABLE>
V-AFC?
By the way, I spent the same thing on my setup, which I should have running in a week.
Old Jun 19, 2004 | 09:13 AM
4potnick's Avatar
Default Re: (krskid)
nice atricle though. made me want to turbo my zc.
Old Jun 19, 2004 | 10:28 AM
mr_valentino20032000's Avatar
Default Re: (4potnick)
Hey does this set up work on a DOHC ZC or is it the SOHC VTEC ZC only? from what i heard the DOHC has low compression and therefor is better for Nos or turbo..but i'd rather go turbo
Old Jun 30, 2004 | 11:04 AM
What engine do you have to start with? A base Civic hatch @ 70hp with a baby 6psi turbo is the deal here. Yes, turbocharging a good Honda setup leads to fast cars. However, the issue here taking a stock D-series motor and adding a small turbo, running low boost (6 psi) so as to not blow the engine, just for the purpose to add 60 hp quickly. It works the same for those little Japan-only cars that have 65 hp with turbo. Just because you have a turbo doesn't make it fast necessarily. A turbo B16 or B18 setup corrcetly will be a quick little car. A D15B1 with turbo will be able to keep up with daily traffic once the turbo spools up. Again, a CHEAP upgrade for under-performing Hondas.
jaybyrd
Apr 5, 2010 03:30 PM
Honduh@Love
Jun 21, 2005 05:20 AM
honda_freak_85
Sep 29, 2004 07:26 PM
Big_Bird
Oct 30, 2003 05:51 PM
tek_civic
Oct 18, 2002 08:51 PM
