HELP!!!! d16a6 into 90 DX!!!!!
ok guys .. brothers motor just blew so this has to happen tonight!!!! or real soon!!! and i have finished all my research on how to swap over to mpfi ....
but i pretty much understand the whole injector part of it ... shouldnt be a problem ...
but what about the dizzy.... ill be using the a6 ecu and i hear u have to do some sort of repinning for the distributor ... how do i do this??? is the repining on the actualy dizzy clip or on the ecu???
besides that is there any other little tricks i need to do to get this swap up and running correctly???
please help me guys!!!!!! and a super huge thanks in advance!!!!!!
The dizzy plug needs to be replaced with one from the Si. The DX one is 2 pins less than the Si one (2 extra injectors).
You could just hardwire , but that would suck if you ever needed to pull the dizzy off for some reason.
u lost me already ... lol im not the brightest one ...
should i be using the stock d15 dizzy of the a6 dizzy??? .... and what do i have to switch over .. do i have to wire to the ecu for the dizzy?? im lost ... lol big suprise!!!
sup dude.. i just recently did this swap after my D15 puked on itself
this is what i followed to get it done. I printed it out so i could have it next to me.
http://www.fourthgenhatch.com/mpfi.html
ahhhh .. ok ... cool .. good page ... so all i have to do is connect the c1 and c2 wires to the dizzy to get it working right then???
yes, but make sure you dont mix them up. Take it slow, and try to label the wires inside the engine bay and on the ECU side of the connections. When your feeding the wire through the firewall right above the ECU from the engine bay take a long screwdriver with your length of wire, elctricol taped to the Screw driver (easy to Twine the two wires by putting them into an electric screw driver.. twists them nicely if you have someone hold them tight oposite of you). then pull the wires through. You prob already knew this, but jsut small help ^_^
Now, just to let you know, he does mention two methods on the ECU side of wiring,... one which requires depinning and the other just cutting. Read through that article i gave you a few times to get a good grasp so you dont mix yourself up. If your depinning, use some strong tweasers or something small and uh, pin like... it took me quite a few tries.....you have to press aginst a clip then push to pop it out, from the opposite side of where the wire comes out
any more Q's just post up, and if your stuck i'll take a pick of my engine bay or whatever....
good luck
One more thing you might run in to (unless you already did it) Next to the Distributor, besides for the two wires that are fed into the ECU, if you are using a DX harness and SI distributor/wires......Use si harnes's plug onto your modified DX harness, and match the colors up the best you can, they can sometimes be off .. ex. light orange... bright orange...... and there will be two white wires there(in some cases) if there is , just switch them if you sence anything wrong...
good luck
ok ... few questions.... in the write up is says to wire the left wire on the injector as the signal wire ..... but, from looking at my 92 hatch i noticed, looking from the front that the right wires were the solid color signal wires ... just the same as the obd0 injector clips that i picked up out of a obd0 teg.....
so i went with my gut feeling and wired the right wire(the solid colors---brown-red-blue-yellow) as the signal wires and then all the red black wires i sent to the resistor box..... does that sound right?????
also .. does it matter which red/black wire goes where to the resistor box????
oh, and also .. that weird looking plug on the back of the pluck.. the one with the two prongs stickout out of it ... do u know which color wire goes onto which plug????
damnit!!! now i have no spark!!! i have everything hardwired .... matching all colors up .... on the si dizzt it apears that the oarange wires are more like a really light orange but they have the same color stripes so i have them matched up ... and ive already tried switching the white wires...... what else should i check besides my grounds???
beatthisspeed69
13
May 5, 2007 01:34 PM
slpnz6
May 10, 2006 03:18 PM
cartracin6
Nov 22, 2004 02:07 PM
shorty91
Jun 23, 2003 11:51 AM
