Locked keys in '92 prelude. Can anyone help?
Saw a post on the CRX / EF Civic forum that said it was easy.
I just registered so I can't use PM yet, so email me
Thanks.
Thanks.
Or - do what the locksmith will do if you're not afraid
you need a spatula (plastic) and a coat hanger
slide the spatula under the rubber seal at the top of the window near the middle where it's loose (est)
get the spatula in and over the top of the window glass, then pry the glass out a little away from the door. then slide the spatula towards the front of the car, working it to directly above the door lock. you should have a slit big enough to slide the hanger down.
make a tiny 'L' in the end of the straightened coat hanger, slide it through the slit and pull the unlock switch up. if you need to, use one hand to pry the glass out more with the spatula.
DON'T BE AFRAID
DON'T BE AFRAID
AnuParmi
Dec 25, 2006 06:47 PM
