What psi to run on A032R?
Should I keep the stock psi? i.e. 35psi for front & 33 psi for rear?
I am talking about for daily driving, thanks for any input
On the track I go to about 30f and 32r. good luck
Bryan
I run 30 all around. The wear looks good and the tires feel fine. When I race (drag) I will take tons of air from the front of course, but for track and street 30/30 works good.
From what I've been told and my experience on the track, the 032R needs to be 36psi when its hot - I check ever time I come off the track. Mind, this is in my Alfa race car, cold pressures are 30psi but it can vary depending on track conditions. Don't know about the ITR - probably higher rear pressures to bring them up to temperature quickly.
IMHO I wouldn't run the 032R on a daily basis unless you are going to the track every day
yeah but when hooking up is a huge issue as with trq steer, A032R's are the best solution minus buying the cheep made 555's. But if you have stock power or close to stock power with mild trq, any good high performance tire is ok.
