del sol susp. on ef
i have a complete del sol susp. setup for my ef hatchback.....my question is will i need to use it all i mean the lca's upper pillow mounts and whatnot.....or can i just use the shocks and springs and forks?
If it's the stock Del Sol setup then you probably won't be able to get the front shocks on. If you do, you will have sucessfully lifted the front of your car about 3 or four inches. If people ask you - I guess you could say your hydros got locked in the UP position.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource »</TD></TR><TR><TD CLASS="quote">92-95 Civics including DelSols have more suspension travel so by installing them in your 88-91 Chassis the height MAY be jacked up.</TD></TR></TABLE>
that's weird because when I bought my rear shocks ( Koni yellows), it had the same part number as del sols...
*I replaced my rear lca's w/ 90-91 ef
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">
*I replaced my rear lca's w/ 90-91 ef</TD></TR></TABLE>
Its the front shocks that matter.
delsolb18b1
May 29, 2006 09:22 PM
deadlock32
Mar 2, 2006 07:36 PM
