Whats needed to put si head on a hf block?
Old Jun 18, 2004 | 04:49 AM
Teal95Coupe's Avatar
Default Whats needed to put si head on a hf block?
Someone is giving me a si head for free and I was wondering what I would need to put it on a hf block. I've already figured headgasket, headbolts, and a si ecu to make it run right. Anything else I should need?
Old Jun 18, 2004 | 05:04 AM
FourthGenHatch's Avatar
Default Re: Whats needed to put si head on a hf block? (Teal95Coupe)
You need to put Si pistons in it also because HFs do not have valve reliefs in the pistons.
Old Jun 18, 2004 | 05:12 AM
Default Re: Whats needed to put si head on a hf block? (FourthGenHatch)
Do the si pistons fit on the hf rods without modification?
Old Jun 18, 2004 | 05:19 AM
WhatThaFrig's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teal95Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Do the si pistons fit on the hf rods without modification?</TD></TR></TABLE>
I believe they are the same rods
Old Jun 18, 2004 | 05:26 AM
Default Re: Whats needed to put si head on a hf block? (WhatThaFrig)
So if the pistons and rods are still good in the SI block then I could just swap them over? I'm not sure if they are though because the reason I'm getting a free head and tranny is the block has a hole in it.
Old Jun 18, 2004 | 06:00 AM
dr_latino999's Avatar
If the block has a hole, maybe the previous owner threw a rod or something fun along those lines. So check the pistons out and see if they are OK, and you can pretty much guess that at least one of the rods has eaten the dust.
Old Jun 18, 2004 | 06:11 AM
Default Re: Whats needed to put si head on a hf block? (dr_latino999)
Yeah I'm figuring something pretty bad went wrong but if the pistons are ok I figure to go ahead if not I'll just save my money for a swap.
Old Jun 18, 2004 | 07:31 AM
hatchback_al's Avatar
i dont think they have the same rods, a6 is a 1.6 and the HF is a 1.5
Old Jun 18, 2004 | 07:57 AM
tgreaves's Avatar
Default Re: Whats needed to put si head on a hf block? (hatchback_al)
The rod journal sizes are different between the si and hf motors.. I know the mains are the same size for the d15b7,b2, and the b6(hf) motors.. So get a crank, rods and pistons from a b2/b7 and put into your hf block and your good to go.. I have a set if your interested..
SlowMotion
Apr 9, 2004 05:45 AM
91krix1127
12
Jul 31, 2003 07:36 PM
crxracr
May 28, 2003 03:17 PM
I Gotta Question
Jan 16, 2003 09:53 AM
Hondasaurs
Apr 14, 2002 10:36 AM
