Help with DPFI to MPFI conversion ! ! !
Old Jun 18, 2004 | 12:44 AM
turblown's Avatar
Default Help with DPFI to MPFI conversion ! ! !
Hey...
I have all of the wiring done. I am just finishing up the Manifold install. I'm just a little confused about the 2 coolant lines coming out of the EACV and a vaccum line coming off the firewalll. It is a ZC Manifold and Throttle body installed in an 88 hatch DX.
Please take a look at the pictures below and let me know what to do... if you have any pics of a correct install that would be great too.
Here is the Back of the Intake Manifold:
Here is the Throttle Body:
So far this is what I have found... and not found:
1. Smaller port (top of TB) = vacuum line to Map Sensor
2. Larger port (top of TB) = red braided line to Charcoal Canister
<FONT COLOR="Red">3. Larger Port (bottom of TB &gt;&gt; leads into bottom of EACV) = connects to ???
4. Larger Port (bottom of EACV) = connects to ???
5. A second vacuum line coming out of a small can next to Map Sensor on firewall = connects to ???</FONT>
Thanks alot for any info you can offer!
-Wes
Old Jun 18, 2004 | 06:22 AM
jolt-tsp's Avatar
Default Re: Help with DPFI to MPFI conversion ! ! ! (turblown)
run the red hose to the top left (the one that's curved) connection on the tb
run the short vacuum hose to the small connection on the right top of the tb
run the long vacuum hose to anywhere on the intake manifold. you might have to T into one of the vacuum lines
i forgot exactly where the iacv hose goes, but i think there should be a connection right next to the heater hose, just under the intake manifold on the back of the engine block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turblown &raquo;</TD></TR><TR><TD CLASS="quote">Hey...
-Wes</TD></TR></TABLE>
Old Jun 18, 2004 | 06:31 AM
USDM 4G VTEC's Avatar
Default Re: Help with DPFI to MPFI conversion ! ! ! (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">run the red hose to the top left (the one that's curved) connection on the tb
what he said
the top lines are the vacum lines for ur MAP and purge solenoid
the two lines on the IACV for coolant goes to the block (by the thermostat and the collant line for the heater, theres a small nipple there) and the other should go to the back on the coolant tube on the back of the block..... it should be another nipple there
Old Jun 18, 2004 | 06:04 PM
turblown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">i forgot exactly where the eacv hose goes, but i think there should be a connection right next to the heater hose, just under the intake manifold on the back of the engine block.</TD></TR></TABLE>
Okay... I think know about the two connections you are talking about. But those connections were orininally connected to a different coolant tube (the tube attached to a second tube running from the air intake to the engine). I'm goint to try it out and see what happens... hopefully it all works out. I'll come back and let you know. Thanks again for all the help!
-Wes
LUKE 92 GS-R
Jun 18, 2008 06:17 PM
95ccoupe
Jun 28, 2007 08:33 PM
SpoonEk253
Feb 15, 2007 05:57 PM
TyeJ23
Aug 31, 2005 07:52 PM
ImportechPerformance
Dec 14, 2004 09:31 AM
