96 Accord brakes?
Old Jun 18, 2004 | 12:12 AM
MayhemSerenade's Avatar
Default 96 Accord brakes?
Just bought a 96 Accord LX. Car kinda shakes and the wheel vibrates when braking. Could this be the rotors, brakes themselves, or what?
Also, anyone framiliar on how to go about making a non-vtec, a vtec.?
1 more thing. Your opinions. Cross drilled rotors, slotted rotors, or crossdrilled and slotted rotors. Advantages and disadvantages to any of these?
Old Jun 18, 2004 | 12:40 AM
Nick H's Avatar
New User
Default Re: 96 Accord brakes? (MayhemSerenade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MayhemSerenade &raquo;</TD></TR><TR><TD CLASS="quote">Just bought a 96 Accord LX. Car kinda shakes and the wheel vibrates when braking. Could this be the rotors, brakes themselves, or what?
well there are various different theories behind this...some say it's warped rotors, while others say that it's uneven pad wear...regardless, both need replaced...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MayhemSerenade &raquo;</TD></TR><TR><TD CLASS="quote">Also, anyone framiliar on how to go about making a non-vtec, a vtec.?
check out this entire thread from another website that is striclty accords...
http://www.accordinglydone.com...=1526
it should answer just about any question you might have regarding a vtec head swap....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MayhemSerenade &raquo;</TD></TR><TR><TD CLASS="quote">1 more thing. Your opinions. Cross drilled rotors, slotted rotors, or crossdrilled and slotted rotors. Advantages and disadvantages to any of these?</TD></TR></TABLE>
for the street, you really aren't going to notice any difference with these kinds of rotors...the reason for this style of rotor is to dissapate heat faster in roadcourse style racing where you are heavy on the brakes often....also, most of these styles of rotors aren't made correctly and often crack where the drills or slots have been machined in...a good cross drilled or slotted rotor is cast into that particular style from the start, and not machined at all....
if you are looking for a brake upgrade, you should check out the legend 2 piston calliper swap...for the price, you can't beat it....you upgrade the rotors to the 11.2 inch accord v6 (95-97) rotors and the larger callipers....it's a great setup and vast improvement over stock with the right pads...here's the details on that swap...
http://www.accordinglydone.com/tech/tech.php?ID=32
good luck...
75aces
Apr 17, 2012 07:43 PM
aztmp.com
Oct 14, 2009 07:17 PM
Nisif
Sep 11, 2006 04:45 PM
J T*
May 17, 2003 10:28 PM
Conechaser
Jun 30, 2001 03:41 AM
