Can't search for 'ZC'. Just picked one up...needs some work. Many questions!!!!!
Old Jun 17, 2004 | 09:37 PM
Jonathan_ED3's Avatar
Default Can't search for 'ZC'. Just picked one up...needs some work. Many questions!!!!!
Selling that bad boy
Modified by Jonathan_EH at 2:10 PM 7/19/2004
Old Jun 17, 2004 | 11:08 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default Re: Can't search for 'ZC'. Just picked one up...needs some work. Many questions!!!!! (Jonathan_EH)
? Oil leak same thing is going on with my dohc zc ?
? and I dont know how to pass emissions?
This list should help you out my want to print it off its almost all you need to know plus some then plus some more.
PART: Alternator Belt 88-91 CRX
PART #: 31110-PM5-305
PRICE: 15.13
PART: A/C Belt 88-91 CRX
PART #: 38920-PM5-A04
PRICE: 15.13
This is for a Denso compressor but yours may be different.
PART: Timing Belt 1988 Prelude 2.0 Si
PART #: 14400-PK2-004
PRICE: 33.58
PART: Engine Mounts 88-91 CRX
PART #: 50821-SH3-040
" "50805-SH3-030
" "50810-SH3-040
" "50840-SH3-000
PRICE: 64.25
" " 58.58
" " 52.85
" " 36.60
PART: Thermostat 88-91 CRX
PART #: 19300-PM3-003
PRICE: 13.67
PART: Crank Seal 89 Integra
PART #: 91212-PE0-662
PRICE:18.63
80x10mm
PART:Rear Main Seal 89 Integra
PART #: 91214-PH3-751
PRICE: 13.28
31x46mm
PART: Cam Oil Seals 89 Integra
PART #:91203-PG6-013
PRICE: 4.77
Need 2 seals
PART: Valve Cover Gasket 89 Integra
PART: Radiator Hose Upper & Lower
1984 Accord - Top
88-91CRX-Bottom
PART #: 19501-PD2-000
PART #: 19502-PM3-000
PRICE: 22.05
PRICE: 22.63 The top hose must be trimmed.
PART: Distributor Cap & Rotor
PART #: 30102-PM5-305
(Integra Part note the PM5)Oddly the OEM Integra cap didn't fit but the Si one did.
PART: Exhaust Gasket 89 Integra
PART #: 18110-PG6-003
PRICE: 15.68
PART: Water Pump 89-91 CRX
PART #: 19200-P01-004
PRICE: 58.83
PART: Oil Filter 88-89 Integra
PART: 88-91 CRX
PART #: 15400-PR3-004
Fram PH3539A
PART: Spark Plug Wires 1989 Integra
PART #: 32722-PG7-A00
PRICE: 42.00
You can get aftermarket. The CRX plugwires sit about 1" off the valve cover.
PART: Throttle Body & TP Sensor 1989-91 CRX / 1988-89 Acura Integra with the D16A1 engine
PRICE: About 40-70 at the junk yard or $300 from dealer Use your old TB if you have an Si or make a trip to the junk yard if you have a DX - you'll have to get a new TB.
ECU (OK) 1989-91 CRX/Civic Si N/A
ECU (Better) 1988-89 Integra 37820-PG7-A013
The part number may vary depending on the year. Junkyard
100.00 Must be 5-speed ECU
ECU (Best) 1989-1991 ZC 37820-PM7-0330 (Not verified) $150-$200
112mph Speed Limit
PART: Spark Plugs 88-89Integra 98-91 CRX NGK BCPR6E-11
PART: Head Gasket 89 Integra
PART #: 12251-PM7-003
PART: Intake Gasket 89 Integra
PART #: 17105-PG6-S00
Si Pressure Plate / Disk
Si Throw Out Bearing
PART: Exhaust Header 88-91 CRX/Civic DC Sports or Kamikaze from
ARD Performance
PART: Stock 88-91 Header with modification
PRICE: After Market $200 to $400
PART: Cam Angle Sensor 88-89 Integra Use Junkyard Replacement
PRICE: $5 - $30
PART: Distributor 88/89 Integra Use Junkyard replacement
PRICE: $100-150
Old Jun 18, 2004 | 09:07 AM
Wow, thanks for the list.
The only thing I don't see on there that I may want to get is the oil pump.
Modified by Jonathan_EH at 2:11 PM 7/19/2004
Old Jun 18, 2004 | 09:19 AM
quis23's Avatar
Default Re: (Jonathan_EH)
http://www.thezcresource.com
devonb456
May 7, 2010 06:32 PM
xsuperxsonx
Texas -OK -LA (Sales)
Oct 8, 2007 07:10 PM
daigo
Feb 8, 2005 07:19 PM
SteveeeO
Dec 13, 2002 11:54 AM
