Alpine Type R 10" sub with which amp?
I'm tryin to help my buddy set up just a sub and amp to add to his ride. He wants a 10" Alpine Type R (RMS: 100-300; Peak: 1000; dual 2-ohm coils)
I'm wondering if this amp would be good enough for it or does he need somethin with a bit more power?
http://www.onlinecarstereo.com...13200
(350 watts RMS X 1 at 2 ohms; Max power: 700)
He is only lookin to spend 5-600 on it, and we still need to set up a box, so if you think this is a bad setup, can i have some other suggestions?
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n0 iNTegRiTY »</TD></TR><TR><TD CLASS="quote">I'm tryin to help my buddy set up just a sub and amp to add to his ride. He wants a 10" Alpine Type R (RMS: 100-300; Peak: 1000; dual 2-ohm coils)
TIA
is that amp stable at 1ohm? the type r is dual 2ohm, and im not sure if you can wire a dvc 2ohm sub to 2ohm
TIA
</TD></TR></TABLE>is that amp stable at 1ohm? the type r is dual 2ohm, and im not sure if you can wire a dvc 2ohm sub to 2ohm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe »</TD></TR><TR><TD CLASS="quote">
you cant... you can only wire a 2 ohm DVC to 4 or 1 ohms... i got dual 4ohm and am gonna run a MRD-M500 to it at about 400-500 watts RMS at 2 ohms... so try to find something that will push that sub around 400-500 at 4 ohms.
</TD></TR></TABLE>you cant... you can only wire a 2 ohm DVC to 4 or 1 ohms... i got dual 4ohm and am gonna run a MRD-M500 to it at about 400-500 watts RMS at 2 ohms... so try to find something that will push that sub around 400-500 at 4 ohms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe »</TD></TR><TR><TD CLASS="quote">
then the amp he is thinking of will NOT suit that subwoofer!
maybe the amp can go to 1ohm but i see no specs for that, i think if it could he could turn down the gain if its too much
but as far as i know alpine amps don't like 1ohm
correct me if im wrong
</TD></TR></TABLE>then the amp he is thinking of will NOT suit that subwoofer!
