FS: 2000 Civic Type R Coupe
Old Jun 17, 2004 | 03:56 PM
oem's Avatar
oem
Default FS: 2000 Civic Type R Coupe
Performance
-B18C5 block 2001 JDM ITR 11.1.1 compression pistons
-Brand new 2001 ITR complete cylinder head purchased from Acura
6 months ago
-Brand new 2001 ITR LSD transmission purchased from Acura 6 months ago
-Brand new ITR clutch and pressure plate
-Fidanza 7.5 lbs flywheel
-Brand new ITR distributor, IAC Valve, throttle body, radiator
-AEM cam gears
-B&M adjustable fuel pressure regulator
-B&M fuel pressure gauge
-JDM ITR header
-JDM CTR N1 Crank Pulley
-Fields SFC VTEC
-JDM P73 ecu
-Custom K&N air intake system
-J's Racing Test Pipe
-5 Zigen catback exhaust system with high-flow resonator
-Goodridge braided stainless steel brake lines
-Gunmetal ITR rims
-ITR clutch master cylinder
-ITR brake booster and master cylinder
-Sir proportioning valve
Suspension
-5 bolt ITR suspension arms & hub conversion
-New front and rear pads and rotors
-Zeal function S coilovers
-Front, Rear and Lower rear strut tower bars
-Civic Sir 26mm front sway bar
-JDM ITR 23mm rear sway bar
-Beaks frame reinforcement kit
-Energy Suspension polyurethane engine mounts
-Hawk Blue pads
Appearance
-Momo Corse steering wheel
-Sparco EVO racing seat
-JDM CTR headlights
-JDM CTR mirrors
-JDM EK Air Bag block off tray
-ITR gauge cluster
-Mugen pedals
- Sir Spoiler
- Sir front and rear oem lips
-Autolock
-Hood lock
-Relocated hood latch
-Fuel cut and ignition switch
-Clifford Alarm
Colour is Milano red, body is in mint condition, no accidents, never winter driven, not a scratch or ding on the entire car.
Entire motor and transmission assembly has 4000 kms. Motor has only seen Mobil 1 Synthetic Oil. I have kept all recipts to prove everything. Everything in this ENTIRE motor is brand new, must see to believe. This car is quicker than an S2000 and can prove it. I have spent over $14,000 on this car in the past year.
Dynoed at 180 hp and 135 ft lbs
$19,500 Cdn
Call 416-721-8686 OR email oem@ipoline.com
Old Jun 17, 2004 | 03:58 PM
MADEinJAPAN's Avatar
Default Re: FS: 2000 Civic Type R Coupe (oem)
Pics?
RopethisS2K
Sep 25, 2006 11:10 AM
RopethisS2K
Northwest (Sales)
55
B16b2b
42
Sep 15, 2003 08:10 AM
b18c1_powered_si
Aug 7, 2003 12:43 PM
12SecHatch
Mar 20, 2003 03:42 PM
