For those of you that are running Toda spec A Cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">toda As don't peak past 8k anyway...
i see no reason to set the rev limiter past stock</TD></TR></TABLE>
the mugen ecu goes to what 9200? .....and that's for stock cams and stock valve springs.
I'd say go at least that high with spec a's. Sometimes you need to leave it in gear..... especially when autoxing or road racing. If you plan to go higher than 9200 rev limiter, then get the toda valve springs for that extra margin of safety.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
mugen DOES NOT recommend the used of their ECU with stock valvesprings
the thread starter didn't indicate he was going to do any of those things
you DO realize that mugen valve springs are simply rebadged honda ones, right?
i have spec a's and have taken the rev limiter to 9200 many times... stock valve springs of course.
Also, I know many on this board running the mugen ecu with their stock cams and valve springs who have been zinging the 9200 limiter there with no ill effects for years now on the street and on track... Ed, care to chime in?
i used to run a 9200 limiter on a stock jdm itr.
i say set your limiter to 9200rpm, but on a drag race shift at the stock 8600 rpm,
would be better to dyno it and find out where the curve is, so this way you know exactlly where your power is.
ricekiller1
Nov 27, 2007 11:25 PM
filipedua
12
Apr 17, 2006 03:58 PM
Edward
Mar 14, 2004 09:03 PM
powerfulperformance
May 5, 2002 05:16 PM
nsx-Animal
Sep 20, 2001 12:50 PM
