whistling noise....HELP!
Old Jun 17, 2004 | 02:16 PM
ae_turbobabie's Avatar
Default 96 gsr with whistling noise....HELP!
Hey I need help, I'm experiencing a high pitch whistling noise coming from the motor on passenger side. I had thought it was the axels, because i did need to change that.. but after it's been fixed, i'm still hearing the same high pitch noise. it get's louder and louder every time i accelerate. it's not the intake... it's BONE STOCK.. HELP..
Old Jun 17, 2004 | 02:21 PM
wreckedmyteg's Avatar
Default Re: 96 gsr with whistling noise....HELP! (ae_turbobabie)
That sounds like the same noise I'm getting (from the description). I only get it at 10% throttle.
bump
Old Jun 17, 2004 | 02:44 PM
pbizzlegsr's Avatar
when you hear the whining whistling noise..right then try taking out your deck..i thoguht it was the motor but it waslinked to the speakers/deck..once i did that with the noise going..it went away..not sure if its your problem but that was the solution for me..as for wrecked my teg..sounds like its your intake..
Old Jun 17, 2004 | 04:41 PM
Medek's Avatar
Default Re: 96 gsr with whistling noise....HELP! (pbizzlegsr)
might be a bad ground on your speakers.. especially if they are aftermarket..(if so choose a new grounding point)
crank your stereo and if the noise gets much louder by doing so.. well then..
when it happened to me the noise level gets higher with RPM and cranking the stereo volume indicated it was a speaker.
Medek's Avatar
Default Re: 96 gsr with whistling noise....HELP! (Medek)
oh.. and dont play any music when doing so
Old Jun 17, 2004 | 06:03 PM
Duo57
Guest
Posts: n/a
Yeah if you have your power cable from your audio too close to your speaker wires you will hear the squeeling noise caused from the alternator, so the more you accel, the louder the belt moves making it louder, turn off your deck completely and see if thats it. People previously mentioned it but yeah it's probably it.
Old Jun 17, 2004 | 09:22 PM
Default Re: 96 gsr with whistling noise....HELP! (Duo57)
its not the deck. im thinking its the WHEEL BEARING on the passenger front wheel. now can i get some help on fixing it.
Old Jun 17, 2004 | 10:01 PM
teg01ls's Avatar
check your gasket seals
Old Jun 17, 2004 | 10:05 PM
Sack Master's Avatar
Default Re: (teg01ls)
Not your brake squeeler? If it's a wheel bearing you'll have to go have someone take it out and press a new one in. It will probably be way cheaper if you take the knuckle off yourself and take just that down to a machine shop with a new bearing and probably hub as well.
Old Jun 17, 2004 | 10:07 PM
andrew dc's Avatar
Default Re: (Sack Master)
flywheel piolt bearing?
Old Jun 17, 2004 | 11:32 PM
Mr. Softee's Avatar
Default Re: (andrew ef)
its pretty easy to tell if its a wheel bearing, you can kind of hear the sound osccilate. It might be a brake shield hitting the wheel or the rotor. Get in there and find out man.
Old Jun 17, 2004 | 11:54 PM
VsR785's Avatar
check or replace the wheel bearings
Old Jun 18, 2004 | 12:14 PM
ernald711's Avatar
bro it could be your throttle body.... stock or not stock after a while (or the initial break in period) the Integra's TB starts to "whistle" at a certain RPM. It's does this when the TB is at a certain angle.
i use this as my "change oil" sound. my teg whistles around 31k and it's pretty distinct. when it's louder than usual at 31k (or slightly higher) i know that i'm using more gas/air and thus, i need an oil change...
like it said... this could it, or it might be something else. good luck
Old Jun 18, 2004 | 01:35 PM
Default Re: 96 gsr with whistling noise....HELP! (ernald711)
I'm not a bro.. i'm a sis.. by the way if you are responding to me.. it can't be beacuse i need an oil change.. I change it every 2500 miles with synthetic.
Old Jun 21, 2004 | 04:24 PM
ernald711's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ae_turbobabie &raquo;</TD></TR><TR><TD CLASS="quote">I'm not a bro.. i'm a sis.. </TD></TR></TABLE>
my mistake.... sorry.... also the TB makes this sound occasionally, usauly louder on mine when "I" need an oil change. not implying you need an oil change. you said that it makes this noise when u accelerate. lister to it and try to find out the certain RPM that it starts to "whistle".
bignelson001
Mar 24, 2011 03:26 AM
jr408
Mar 19, 2008 09:18 AM
Mike banX
May 19, 2005 05:03 AM
ibanezrgking
May 19, 2002 08:29 PM
