1k-1500$ best ideas to put into gsr engine, HELP!
Old Jun 17, 2004 | 01:28 PM
orangegsr's Avatar
Default 1k-1500$ best ideas to put into gsr engine, HELP!
so i have a 94 gsr, just finished my exterior, and now i want to put some work into my engine. with college coming up i assume i'll only be able to put about 1000-1500 into it. i have the oh-so-common basics, dc header, exhaust, intake, plug wires.... i'd love to turbo/ s/c , but i doubt that kind of budget would be able to pull it off. if thats the case, what else would my money be most well spent on, to get the most power out of my engine
Old Jun 17, 2004 | 01:34 PM
Mr. Softee's Avatar
Default Re: 1k-1500$ best ideas to put into gsr engine, HELP! (orangegsr)
sell your POS header, intake and exhaust setup. you should have more than 2 g's to work with. That is easily enough to turbo your car and make 300whp.
Old Jun 17, 2004 | 02:47 PM
orangegsr's Avatar
ok lets try this again..i have a 1k-1500$ budget here, what parts/work would give me the most power with that kind of money
Old Jun 17, 2004 | 02:49 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
just buy intake, header, exhaust, a VAFC, cluthc and Flywheel. those are the most basic and make the biggest differeces
ThePro's Avatar
Clutch, VAFC, cam gears, new cams and valve train and a bunch of tuning
Old Jun 17, 2004 | 03:05 PM
FunkDaddyFresh's Avatar
why dont you try and search.... this post is almost in this board everyother day... it isnt that hard to figure out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangegsr &raquo;</TD></TR><TR><TD CLASS="quote">ok lets try this again..i have a 1k-1500$ budget here, what parts/work would give me the most power with that kind of money</TD></TR></TABLE>
Old Jun 17, 2004 | 06:29 PM
RallyRedGT-V6's Avatar
Default Re: 1k-1500$ best ideas to put into gsr engine, HELP! (FunkDaddyFresh)
wow, dont you ******** ever read
HE ALREADY HAS I/H/E
stop telling him to do it again
look in the classified, every now and then someone is selling a decent kit for like 1200...take it, and the other 300 and get that **** tuned
Old Jun 17, 2004 | 06:39 PM
m R g S r's Avatar
Default Re: 1k-1500$ best ideas to put into gsr engine, HELP! (96integra)
Just supercharge it, you already spent the money on the exhaust and header. I gurantee you can find a jackson racing SC on here for 1500. Look in the Forced Induction classifides.
Old Jun 17, 2004 | 06:48 PM
Mr. Softee's Avatar
Default Re: 1k-1500$ best ideas to put into gsr engine, HELP! (m R g S r)
sell the i/h/e and turbo your car. i/h/e/c is a waste unless you up your compression or get much nicer components than you can afford.
Old Jun 17, 2004 | 06:58 PM
Ti3d in's Avatar
Default Re: 1k-1500$ best ideas to put into gsr engine, HELP! (94goldjungsr)
I agree. Save up more money and put that towards turbo. The basic bolts don't make that much power unless you do more serious mods like cams and headwork.
Old Jun 17, 2004 | 07:05 PM
Mr. Softee's Avatar
Default Re: 1k-1500$ best ideas to put into gsr engine, HELP! (Ti3d in)
its only worthwhile if you get a nice smsp or toda header and some jun3s or toda Bs, then you need valvetrain, tuning etc... and for the $ you should have just turbeaued.
Old Jun 17, 2004 | 07:08 PM
dsosa51's Avatar
intake, exaust, clutch, flywheel, chiped ecu, type r cams
Oh yea get it tunned
Old Jun 17, 2004 | 07:20 PM
rcurry14's Avatar
if you are going to collage i would not turbo because something will probably happen and you wont have the money to fix it.
Old Jun 17, 2004 | 08:07 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: (rcurry14)
I vote for mild cams (maybe CTR/ITR cams), cam gears, VAFC, FPR and gauge and use the rest for tuning. (estimated cost if bought good used parts on h/t: ~$650. Tuning is probably about $150.)
What do you have in terms of suspension bits? Maybe use the rest on handling.
Good luck!
Old Jun 17, 2004 | 10:20 PM
Briansturboteggy's Avatar
Default Re: (Gee3)
TURBO TURBO TURBO, got a semi kit for sale asking 1k
Old Jun 18, 2004 | 12:47 PM
ernald711's Avatar
Default Re: (Briansturboteggy)
Damn you guys are all harsh... lets try to be constructive here and help this bro out...
okay since I DID READ the posts before... and you ALREADY have I/H/E and plugs. i'd say that that's it for more horses unless you want to set up for turbo. $1500 can also get you a NOS kit.
i'd say forget the power and go with timing. get yourself some cams gears and shafts. depending on where you want your power band you can advance or retard your timing to move your power (i.e. top end response vs. low end) your not gonna get any horses outta this, but you will have extra cash for a VAFC and find a place that could tune your ECU for your specific mods and how you want your car behave.
Now I know that you only want to put your money to your engine, but have you thought about a more responsive ride. For under $1500 you could get yourself either a lightened flywheel/pressure plate/clutch combo or shocks and springs combo with enough money for full struts and sway...
endless ideas with $1500.... good luck on your decision and college bro!!!
Old Jun 18, 2004 | 12:56 PM
rusteds2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti3d in &raquo;</TD></TR><TR><TD CLASS="quote">I agree. Save up more money and put that towards turbo. The basic bolts don't make that much power unless you do more serious mods like cams and headwork. </TD></TR></TABLE>
Agree.
But if are planning on going turbo, do alot of research before doing so.
Razz
Nov 29, 2012 10:21 AM
SetInMotion
Mar 12, 2010 09:54 PM
f22suzuka
12
Apr 30, 2004 06:18 PM
marcusqb5
Mar 15, 2004 06:34 AM
type_sml
Mar 29, 2002 04:05 PM
