Car stuttering wont go nowhere
Old Jun 17, 2004 | 12:02 PM
EF9Si-T's Avatar
Default Car stuttering wont go nowhere
like the topic says, its stuttering and it wont go nowhere. ITs an 88 4dr ef dualpoint. For some reason the check engine light has not come on but I know it works cause I can see right before the car turns on. I already check the computer for codes and I got 1,7,8 and 16. I do know what they mean but i dont know where to start on fixing what ever is wrong. YES I DID A SEARCH, but noone talks about how to fix any of these problems, what i mean is having the computer throw these codes and the check engine light not even flashing once.
Old Jun 17, 2004 | 12:43 PM
89civicracer's Avatar
Default Re: Car stuttering wont go nowhere (BUG_MANIAC)
you said you did a search for the codes? right,
i had code 8 and that was the TPS sensor, 1,is the O2 sensor. I know these cause i just fixed those two. . the others i have no clue. . i have found them online though.
Old Jun 17, 2004 | 12:47 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
1988-1991 Honda CRX
The ECU is located at the front of the passenger footwell, under the carpet. There is a single flashing light in the center of the ECU that flashes the codes. Simply count the flashes in each sequence to determine the code.
Code 0 _____ Faulty ECU
Code 1 _____ Oxygen content
Code 2 _____ Does not appear to exist
Code 3 _____ MAP sensor
Code 4 _____ Crank angle sensor
Code 5 _____ MAP sensor again
Code 6 _____ Coolant temperature
Code 7 _____ Throttle angle
Code 8 _____ Top dead center sensor
Code 9 _____ No. 1 cylinder position (only on 1.6L)
Code 10 ____ Intake air temperature
Code 11 ____ Does not appear to exist
Code 12 ____ Exhaust gas recirculation system
Code 13 ____ Atmosphric Pressure
Code 14 ____ Electronic air control (EACV)
Code 15 ____ Ignition output signal
Code 16 ____ Fuel injector
Code 17 ____ Vehicle speed sensor
Code 18 ____ Does not appear to exist
Code 19 ____ Lock up control solenoid (auto trans only)
Code 20 ____ Electric load
hope this helps...
Old Jun 17, 2004 | 01:11 PM
egchan's Avatar
do you have a swap?
Old Jun 17, 2004 | 03:23 PM
Default Re: Car stuttering wont go nowhere (SlickCRX)
I've got a swap. . and occasionally mine putters. . i thougt it was bad wires, but i got new ones and it still putters. .only at low RPM's. under 2K.
Old Jun 17, 2004 | 07:21 PM
EF9Si-T's Avatar
Default Re: (dgonzals)
big dog i know what all the codes mean but my question was where the top dead center sensor is? how do i check for code 16, and what about the TPS where do i find this on the car? THANKS FOR THE CODES THOUGH any bit of info helps. Oh and i dont have a swap i have a stock engine as stock as stock gets. Oh and earlier i was driving to the liquor and it completely died out I had to get a jump, I dont know why because i just put a new alternator and battery. HELP ALL U PROS OUT THERE!
Darth CRX
Apr 29, 2014 07:33 AM
Jer'rome
Honda Civic (2001 - 2005)
Nov 2, 2007 02:19 PM
bstaralways
Sep 4, 2007 02:51 PM
ph0shizzle
May 13, 2006 08:36 PM
EFin' Kyle
Sep 29, 2004 07:47 PM
