Speedometer?
Old Jun 17, 2004 | 09:17 AM
silverspins's Avatar
Default Speedometer?
I did a B18A swap into my CRX, and how do I get the speedometer to work? I plugged the cable that rotates into the transmission, do I just have to remove it and try a few times or what?
Old Jun 17, 2004 | 10:02 AM
EF_LSVtec's Avatar
Default Re: Speedometer? (silverspins)
Try jiggling the cable around...it worked for me. or you can also pull your cluster out, drive a block and see if the cable is actually turning. Jiggle it some more if it doesnt, hehe...
*I'm assuming too that you are using a 91 teg speedo cable...I remember I had to change mine when I did my swap. Although I read somewhere that stock ones work too but you have to flip the bracket or something...maybe jiggle it too
GPC91
Sep 17, 2012 01:11 PM
johnnyonth3spot
Jun 22, 2008 11:24 AM
rewerbcrx
Jul 19, 2007 04:28 PM
mahatma
Aug 12, 2006 08:20 AM
vitrox
Nov 7, 2004 09:02 PM
