Mount Question
Old Jun 17, 2004 | 06:19 AM
Smooth_Imports's Avatar
Default Mount Question
I've search many sites and have found lots of info on this but i'm still confused.
I'm swaping a B18B into an EK. My question is about the mounts and Brackets.
From what i understand i'm going to need the following. Please let me know if this information is correct.
Brackets
1.96-97 Del Sol DOHC AC bracket
2.99-00 SI Rear motor bracket
3.96-00 LS Front Tranny Bracket
4.96-00 LS top Tranny Bracket
I really get confused about the mounts/brackets. When i say mounts i'm talking about the rubber/poly hookups.
So after i get all those brackets can i just buy all 99-00 SI mounts?
If anyone can help that would be great as you can tell i'm chasing my own tail. I've already done the two wiring fixes and just need someone to set me straight on the bracket/mounting parts.
Thank you,
Magnum
Old Jun 17, 2004 | 06:26 AM
VTECVillain's Avatar
Default Re: Mount Question (Smooth_Imports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smooth_Imports &raquo;</TD></TR><TR><TD CLASS="quote">Brackets
4.96-00 LS top Tranny Bracket</TD></TR></TABLE>
1. YES
2. YES
3. YES although any 94-01 Integra, 99-00 Si or Del Sol VTEC will work
4. NO - you need to reuse your stock D series upper tranny bracket/mount
One very important piece that you are missing is the 99-00 Civic Si Driver's side engine mount bracket - this is a must! You need the bracket that bolts to the motor then you reuse your stock D series rubber mount.
Old Jun 17, 2004 | 06:36 AM
Default Re: Mount Question (VTECVillain)
Thank you for clearing this up for me. I'm going to order the parts right now. Would it be better to order some poly mounts instead of using the stock rubber ones. They look dry rotted and cracked.
jackedupEK9
Sep 29, 2006 10:50 AM
b18c 94
Dec 28, 2004 08:42 PM
CNSK
Aug 5, 2004 12:36 PM
Axemurderer23
Apr 12, 2004 01:22 PM
Mag00n
17
Apr 11, 2004 08:30 PM
