Car won't Start
Old Jun 16, 2004 | 11:15 PM
ludicrous's Avatar
Default Car won't Start
Hi,
I'm having a problem with my 93 Prelude S.
When the weather is hot, for soem reason the car will not start. But when it's cool, it starts fine.
The Car cranks, but does not want to start.
Does anyone have any suggestions on what to do.
Thanks in Advance
Old Jun 17, 2004 | 07:25 AM
Prelude MIke's Avatar
Default Re: Car won't Start (ludicrous)
im having the same issue seems in hot weather it radomly doesnt start. Do you have any mods, might be able to pin down the source if we compare a few things.
Old Jun 17, 2004 | 07:42 AM
Pr0jektLude's Avatar
lol same problem....someone told me its the main relay they were made like ****...in the heat the wires expand and crack. Try banging the drivers side dash by the a/c vent a couple times and try it again. I need to get me a new relay but thats what seems to be the problem.
no relay=no power to fuel pump=no fuel=no start
Old Jun 17, 2004 | 08:56 AM
Yield's Avatar
Default Re: Car won't Start (Pr0jektLude)
definitely the main relay - go to honda and pick one up. It's located under the dash in the driver footwell. Crawl down there and look up by where your left foot would be and you should see a little box. Pop the old part out and put the new one in. I'm sure this has been covered a million times so search if you need further instructions.
Old Jun 17, 2004 | 10:13 AM
SKDRCR's Avatar
Default Re: Car won't Start (Yield)
If it doesn't end up being the main relay, i could also be the ignitor.
Old Jun 17, 2004 | 10:14 AM
prelittlelude's Avatar
didn't even read the thred,
first thinkthat comes to mind is main relay, all i saw was the word weather/.
Old Jun 17, 2004 | 08:20 PM
Default Re: Car won't Start (prelittlelude)
yeah, another common problem with the 92-93 preludes is the ignition module, i also had to replace that.
EfBooth
Oct 18, 2011 10:47 AM
nismogrendel
Apr 24, 2010 01:43 AM
black94lude
Jul 30, 2009 02:11 PM
90jdmcrxdude
Aug 5, 2006 07:34 AM
tboss
Sep 26, 2003 06:30 AM
