what is a civic STD ??
Old Jun 16, 2004 | 06:26 PM
terminaloverlowd's Avatar
Default what is a civic STD ??
is that another term for a 4dr ED ??
(trying to search for an answer to my axle question and i found this line
91 Civic Si axles will fit all 88-91 CRX/Civic Si and DX - will not fit at hub end on Civic STD or CRXHF
i have 91 civic si axles and a 90 4dr DX..
is an STD the same thing as a 4dr DX ?
Old Jun 16, 2004 | 06:27 PM
LSVTEC 91 Civic's Avatar
Banned
Standard (HB) - Not sure which engine came in them.
Modified by LSVTEC 91 Civic at 3:37 AM 6/17/2004
Old Jun 16, 2004 | 07:04 PM
Default Re: (LSVTEC 91 Civic)
so all STD's are HB's ? there's no STD 4dr DX ?
Old Jun 16, 2004 | 07:10 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (terminaloverlowd)
no only came on hatchback. you can tell you have a std hatch, if you have a 1.5 ltr motor with dpfi, one mirror (driverside) , 4 speed,
Old Jun 16, 2004 | 07:11 PM
Default Re: (Hybrid Hatchback)
i've got a 4dr DX 5spd 1 mirror..
apperantly NOT an STD..
Old Jun 16, 2004 | 07:13 PM
beaterdriver's Avatar
i thought it was the station wagon
Old Jun 16, 2004 | 07:14 PM
kaoss_11's Avatar
B A N N E D
Actually i have both my mirrors and mine is a 5 speed. It comes with the powerful d15b1 300 hp and 258 torque. j/k
and no rpm guage.
Old Jun 16, 2004 | 07:15 PM
EG8R's Avatar
Default Re: (beaterdriver)
STD hatch. Same as Canadian CX.
HatchBox's Avatar
Skoobie no more...
Default Re: (kaoss_11)
then you dont have a STD ... good for you son.
i on the other hand do...but its packin a little more then the stock 60 hp
Old Jun 16, 2004 | 07:36 PM
kaoss_11's Avatar
B A N N E D
i am happy for you dad
Old Jun 16, 2004 | 07:40 PM
dragsource hatch's Avatar
glad i dont have an STD
Old Jun 16, 2004 | 08:16 PM
hammerdgolfer's Avatar
std are POS
4 speed
the axles are different so if you do a swap you need a adapter for the new axles to go into the hub or you need dx/si hubs
dx have only 1 mirror and a 1.5 dpfi also
Old Jun 16, 2004 | 08:18 PM
Default Re: (hammerdgolfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hammerdgolfer &raquo;</TD></TR><TR><TD CLASS="quote">dx have only 1 mirror and a 1.5 dpfi also</TD></TR></TABLE>
not any more
heh
Old Jun 16, 2004 | 08:52 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">i am happy for you dad </TD></TR></TABLE>
ROFL!!! Good to see the family love in here.
Old Jun 16, 2004 | 08:59 PM
Westrock2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver &raquo;</TD></TR><TR><TD CLASS="quote">i thought it was the station wagon</TD></TR></TABLE>
me too
Old Jun 16, 2004 | 09:00 PM
lunchboxEF91's Avatar
&lt;==std driver. Its pretty much power nothing. and 4 gears.
Old Jun 16, 2004 | 09:04 PM
4crx4me's Avatar
Default Re: (Westrock2000)
Sometimes the non-Si CRX is referred to as a STD. Though it's usually called the DX. It's not really a STD, cause it has a 5 speed not a 4. Canada could be different though.
Just my .02 cents
Old Jun 16, 2004 | 09:13 PM
sodacan33's Avatar
std are not pos if u do a few upgrades, oh an the axle thing your wrong about thats the crx hf that has the smaller axle- think there 26 spline
Old Jun 16, 2004 | 09:30 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (sodacan33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hammerdgolfer &raquo;</TD></TR><TR><TD CLASS="quote">std are POS
4 speed
Yeah, who wants a lightweight car.... psssh not me.
std = greatest car to do a swap in
Old Jun 16, 2004 | 10:41 PM
got my 'stock' axles put in..
for the record, i counted 26 splines on my 90 DX 4dr.. if that means anything..
the axles that came with the engine/tranny were 23 spline..
Old Jun 17, 2004 | 04:45 AM
Rhonda's Avatar
The STD is a 4 speed base model but not the same as the Canadian Cx. The Canadian Cx comes with 2 mirrors, and a 5 speed transmission.
Old Jun 17, 2004 | 05:24 AM
wtf what is lighter about that car then a dx? the weight of the 5th gear maybe? and the fucked up hubs, i had a b series swap from a std and it took me a while to figure out that the car it was out of was a std becaus theaxles wouldnt fit my hubs, to bad i broke them becaus i coulda sold themfor alot
Old Jun 17, 2004 | 06:33 AM
sd.coupe's Avatar
i sure as hell do have a std!. loving the one mirror.
Old Jun 17, 2004 | 06:34 AM
91civicDXdude's Avatar
the standard does in fact share axles & hubs with the CRX HF. If you're swapping in another transmission from a DX or Si, you can use the STD axles as all of the inner axle spline counts are the same on d and b series, but the spline count in the hub is the difference.
D series into STD = use STD axles, or swap hubs with a DX/LX/EX/Si and use those respective axles.
B series into STD = *must* swap hubs & axles.
Old Jun 17, 2004 | 06:57 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (sdhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sdhatch &raquo;</TD></TR><TR><TD CLASS="quote">i sure as hell do have a std!. loving the one mirror.</TD></TR></TABLE>
im loving that, and the fact its under 2000 lbs with me in it
