crx's with teg rear disk swap, i need help
Old Jun 16, 2004 | 05:37 PM
mrtoastyjr's Avatar
Default crx's with teg rear disk swap, i need help
well i have an 88 si and im getting everything together that i need to do this rear swap and i want to tell you guys what i have and have done and if you see something i missed let me know
*got the trailing arms off and pretty clean and get new es bushing put in
*took everything apart (calipers, sliders ect.) everything looks fine except one slider is stuck but no big deal, clean it up and good as new
*got a rear camber kit, you know while im in there
*ordered some edlebrok stainless brake lines for a 90 teg, just for some insurance
*don't know what to do about the e-brake cables yet, a foot to long, any susggestions
*and also is there anything else i need from the teg, i bought the whole car for the engine and brakes, so anything that i can use from the teg i can strip no problem just let me know what you guys think.
thanx
nate
Old Jun 16, 2004 | 05:52 PM
EL Vap133's Avatar
Default Re: crx's with teg rear disk swap, i need help (mrtoastyjr)
If you can't loop the ebrake cables, then get 90-91 crx si e-brake cables.
Use the Master Cylinder and Brake Booster as well.
Old Jun 16, 2004 | 06:07 PM
Targa250R's Avatar
be professional
Default Re: crx's with teg rear disk swap, i need help (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Use the Master Cylinder and Brake Booster as well. </TD></TR></TABLE>
A great idea, since you have the entire car right there.
Don't forget to swap proportioning valves as well (unless your Integra is a GS or GSR with ABS).
Old Jun 16, 2004 | 06:15 PM
mrtoastyjr's Avatar
Default Re: crx's with teg rear disk swap, i need help (Targa250R)
its a 90 ls and do you know if they (prop. valve) will swap no problem or will i have to modify the lines(not sure, didn't look close at it yet)
nate
Old Jun 16, 2004 | 06:25 PM
4DRmafia's Avatar
speaking of rear brakes, i didnt mean to jack in but i put on mines but i got this rear dsic from the other civic and i dont know where this came from the crx or the teg so im asking how can i find out where it came from and can i use the integra booster and mc if the rear disc is from crx ?
Old Jun 16, 2004 | 06:27 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtoastyjr &raquo;</TD></TR><TR><TD CLASS="quote">its a 90 ls and do you know if they (prop. valve) will swap no problem or will i have to modify the lines(not sure, didn't look close at it yet)
nate</TD></TR></TABLE>
No it falls right into place. USE A 10MM line wrench. ANything else will strip it, these lines are very tight.
I didnt change out the bushings (should have filled them but dont know why i didnt FAWK) Brake booster.. why would you use that from the teg. There is no need, wont make a difference anyway possible. Just use the 15/16MC (recommended) and the 40/40 prov valve (essential) and your set. i didnt even swap MC's. I used some russells SS brake lines, i bought mine for the 90-91 Crx Si and they fit perfectly. Ebrake cables were put in a half loop where control arm bolts to compensator arm.
Dont brake the 10 dollar a piece suspention bolts, its a PITA to drill the old **** outa the bushing. Take your TIME.
-Eric
Old Jun 16, 2004 | 06:30 PM
4DRmafia's Avatar
ok what did the 15/16 mc came from and the 40/40 valve came from, i thought the 15/16 mc bolts different in the civic booster ?
Old Jun 16, 2004 | 06:36 PM
mrtoastyjr's Avatar
Default Re: crx's with teg rear disk swap, i need help (HamiltonRex)
do MC typically wear out after 200,000 miles, well i guess anything does. reason being is that i didn't drive the car but a hundred miles before i parked it and i don't know the condition of the mc but if it'll help then i guess i have no other options.
anybody know what mc run with core charges?
Old Jun 16, 2004 | 07:00 PM
mrtoastyjr's Avatar
bump
Old Jun 16, 2004 | 07:02 PM
TIRENECK's Avatar
what are you going to do with the stock crx drums? I need the left side, hehe.
Old Jun 16, 2004 | 08:57 PM
EL Vap133's Avatar
Default Re: crx's with teg rear disk swap, i need help (TIRENECK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK &raquo;</TD></TR><TR><TD CLASS="quote">what are you going to do with the stock crx drums? I need the left side, hehe.</TD></TR></TABLE>
Do you need the complete trailing arm assembly?
Old Jun 16, 2004 | 09:31 PM
4DRmafia's Avatar
what did the 15/16 mc came from and the 40/40 valve came from and i thought the 15/16 wont work with the stock civic and refering to http://www.fourthgenhatch.com and look for brake.....something
Old Jun 16, 2004 | 09:46 PM
Targa250R's Avatar
be professional
Default Re: (civicsidude91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsidude91 &raquo;</TD></TR><TR><TD CLASS="quote">speaking of rear brakes, i didnt mean to jack in but i put on mines but i got this rear dsic from the other civic and i dont know where this came from the crx or the teg so im asking how can i find out where it came from and can i use the integra booster and mc if the rear disc is from crx ?</TD></TR></TABLE>
CRX rear discs are smaller than Integra rear discs.
Yes, you can use the Integra booster and master cylinder with CRX discs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsidude91 &raquo;</TD></TR><TR><TD CLASS="quote">what did the 15/16 mc came from and the 40/40 valve came from and i thought the 15/16 wont work with the stock civic and refering to http://www.fourthgenhatch.com and look for brake.....something </TD></TR></TABLE>
15/16" master cylinder came from the '90-91 Civic EX sedan. It will bolt right on to the stock Civic booster.
Old Jun 16, 2004 | 09:48 PM
4DRmafia's Avatar
oka ...figures
Old Jun 17, 2004 | 04:01 AM
It also came from older preludes and integra's.
I got my MC and prop valve from the 91 Integra. It will bolt to your brake booster/ where the brake lines are.
-Eric
Old Jun 17, 2004 | 09:26 AM
TIRENECK's Avatar
Default Re: (HamiltonRex)
Do you need the complete trailing arm assembly? </TD></TR></TABLE>
yea the whole trailing arm minus stuff i can replace out the old one, E cable etc. I hit a curb and the drum bended in.
Old Jun 17, 2004 | 10:24 AM
EL Vap133's Avatar
Default Re: (TIRENECK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
CRX rear discs are smaller than Integra rear discs.</TD></TR></TABLE>
You sure about that?
yea the whole trailing arm minus stuff i can replace out the old one, E cable etc. I hit a curb and the drum bended in.</TD></TR></TABLE>
I know I have one, let me check what side I have.
Old Jun 18, 2004 | 02:50 AM
Targa250R's Avatar
be professional
Default Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">You sure about that?</TD></TR></TABLE>
I am sure . . . that I am incorrect Good catch, my mistake.
Learned something new today - my CRX and Civic both use the same rear rotors.
Old Jun 18, 2004 | 04:46 AM
Fobtions's Avatar
Default Re: (Targa250R)
Learned something new today - my CRX and Civic both use the same rear rotors.</TD></TR></TABLE>
yea , if that were true i would be screwed. i have one side off a 90-91 integra and one side off a crx. lol heres a pic just for the hell of it. i used the crx ebrake cables.
Old Jun 18, 2004 | 05:49 AM
Default Re: (Fobtions)
I was sure integra rear discs were bigger then crx's.
Does anyone have some spec's i could compare. I dont really take anyones word around here anymore.
-Eric
Old Jun 18, 2004 | 06:15 AM
Fobtions's Avatar
dude they are the same, i layed one rotor on top of the other. hell even the 94-up integra discs are the same.
Old Jun 18, 2004 | 06:31 AM
hondahans's Avatar
The disc diameter is the same at 9 and 13/32, but the caliper piston bore on the DA integra is larger at 1 and 9/16 compared to the CRX at 1 and 3/16. For the E brake issue, just switch sides. I ran the DA passenger side through the drivers slot and vice versa. It works well and takes the slack out of it all.
You will also be fine using the Si MC and Booster, just be sure to get the 4040 prop valve if you don't already have one.
Old Jun 18, 2004 | 11:28 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">I was sure integra rear discs were bigger then crx's.
-Eric</TD></TR></TABLE>
I used to sell rear disc brake conversions, I measured 94+ Teg, 99-00 SI, and 90-91 crx si rear disc brakes and they were all the same. Damn I should have taken a pic!
Old Jun 18, 2004 | 11:10 PM
Fobtions's Avatar
I used to sell rear disc brake conversions, I measured 94+ Teg, 99-00 SI, and 90-91 crx si rear disc brakes and they were all the same. Damn I should have taken a pic! </TD></TR></TABLE>
yea, i stared at many different years. didnt find any difference, so i picked the trailing arms with the best trailing arm bushing.
Old Jun 21, 2004 | 06:17 AM
crxgator's Avatar
you need the brake booster from the integra if you want to use the master cylinder from the integra, otherwise it wont bolt up... if he wants to keep his stock brake booster, then he needs the master cylinder from an older prelude, accord lxi or 90-91 civic ex...
