Y8 block with Y7 head in 90 civic timing off?
Old Jun 16, 2004 | 04:34 PM
Jockobo's Avatar
Default Y8 block with Y7 head in 90 civic timing off?
I have a Y8 block with a Y7 head and a A6 intake manifold and I'm getting a code 9 and the timing when checked with a timing light is off by a good amount in the advanced position...I checked over the wires and they all seem to go to the right place. I also get a code 9 but the distributor is brand new. This is in a Std model do I had to rewire the car for mpfi. is the cam timing correct on a y7 head on a y8 block? does the distributor mount in the correct position or is it mounted in teh wrong position therefore causing the advanced timing and code 9? Im stumped...
Old Jun 16, 2004 | 04:58 PM
EG8R's Avatar
Default Re: Y8 block with Y7 head in 90 civic timing off? (Jockobo)
Did you wire it for MPFI?
Old Jun 16, 2004 | 05:18 PM
Jockobo's Avatar
Default Re: Y8 block with Y7 head in 90 civic timing off? (skelly ed666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 &raquo;</TD></TR><TR><TD CLASS="quote">Did you wire it for MPFI?</TD></TR></TABLE>
yup
Old Jun 16, 2004 | 09:30 PM
Jockobo's Avatar
86crxowner
Dec 2, 2014 01:02 PM
krazy_23
Mar 25, 2014 03:26 PM
Catman316
Jan 26, 2005 08:13 AM
Civiclx
Nov 22, 2003 09:34 PM
