crossmember?
Old Jun 16, 2004 | 01:50 PM
typeeg's Avatar
Default crossmember?
I am not used to the earlier model civics.. only dealt with eg and ek.. on my new ef I noticed there are two bars going diagonally from the front control arm to the front of the car... is this called the "crossmember"? why do these civics come equipped with this when the newer ones dont? What purpose does it serve and is it worth it to replace these bars with say upgraded thicker bars?
Old Jun 16, 2004 | 02:04 PM
eda6's Avatar
Default Re: crossmember? (StockEG9)
the two bars you're describing are called radius rods.
Crossmember is what the radius rods bolt on to in front.
Two holes on other end of radius rod bolt to lower control arm.
I don't know why newer ones don't have them.
they keep your front lcas in place .
Took me 5 min to cut through one radius rod w/a sawzall.
I don't see a need to upgrade.
Modified by eda6 hb at 12:19 AM 6/17/2004
Old Jun 22, 2004 | 01:03 AM
MestizoRacer310's Avatar
Default Re: crossmember? (eda6 hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">the two bars you're describing are called radius rods.
they keep your front lcas in place .</TD></TR></TABLE>
Good to know..learn something new everyday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">Took me 5 min to cut through one radius rod w/a sawzall.</TD></TR></TABLE>
Just curious as to why you found the need to cut through one.???
Tippyman
Welding / Fabrication
Jul 19, 2014 03:05 PM
night
Jan 22, 2011 06:55 AM
rice r0cket
Mar 15, 2004 10:13 PM
5.0 Killa
Dec 4, 2003 10:16 AM
Kwuaymaikrup
Apr 10, 2003 08:02 AM
