atp exhaust housing question
Old Jun 16, 2004 | 08:53 AM
nevin's Avatar
Default atp exhaust housing question
EDIT: New question... (Assuming that the atp housing is ford) Is the ford t3 exhaust housing the same shape/design as a garett unit or will I need to get a new downpipe made?
This is from the atp "drop in" T3 flanged gt28rs. They modified it from t25/internal wg to t3/external wg.
Here is the t25 one from garret:
http://www.kztuning.com/pix/turbo6.jpg
http://www.kztuning.com/pix/turbo7.jpg
Here is the atp ex. housing. My Question is; if it is setup for external wastegate, what is the smaller hole for?
Modified by nevin at 3:30 PM 10/10/2004
Modified by nevin at 3:32 PM 10/10/2004
Old Jun 16, 2004 | 08:59 AM
Turbocivic94's Avatar
Default Re: atp exhaust housing question (nevin)
the smaller hole gets covered by the downpipe flange
Old Jun 16, 2004 | 09:15 AM
nevin's Avatar
Default Re: atp exhaust housing question (Turbocivic94)
I figured that much... but whats the point of it being there other than disrupting flow to the turbine and causing a possible exhaust leak? I was going to weld it shut but wasn't sure if it had some purpose.
Old Jun 16, 2004 | 09:38 AM
hulkhb's Avatar
Not sure about the peice your asking about but ATP's customer service and knowledge of product its noting but top knotch.
Old Jun 16, 2004 | 03:42 PM
nevin's Avatar
up
Old Jun 17, 2004 | 09:03 PM
turbopimp's Avatar
Default Re: (nevin)
If you're utilizing an external gate then the hole is useless, and is blocked by the DP flange. ATP probably retained the hole from the Ford T3 style housing to cut down on tooling costs, just in case someone needed an exhaust housing w/ the internal flapper valve.
Old Jun 17, 2004 | 10:41 PM
nevin's Avatar
Allright thanks, that makes sense. I will have it sealed up then.
Old Oct 10, 2004 | 12:11 PM
nevin's Avatar
Default Re: (turbopimp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbopimp &raquo;</TD></TR><TR><TD CLASS="quote">If you're utilizing an external gate then the hole is useless, and is blocked by the DP flange. ATP probably retained the hole from the Ford T3 style housing to cut down on tooling costs, just in case someone needed an exhaust housing w/ the internal flapper valve. </TD></TR></TABLE>
Is the ford t3 housing the same design as a garett t3 housing considering they are both 5 bolt or will I need to get a new downpipe made.
manuel12
May 30, 2009 09:48 PM
b_series_boy
Oct 24, 2004 10:31 PM
Evil EG
Aug 4, 2003 11:34 AM
lsvtec101
Apr 6, 2003 03:20 PM
