Oiling Comptech filter
Being in Australia I can't get the Uni foam filter oil that Comptech sell for their filters. I've had various suggestions and I'm hoping someone on this board can vouch for any of them:
1) Use K&N filter oil instead
2) Use oil for foam motorcycle filters
Anyone had experience using anything but the Comptech filter oil?
TIA
ntt
TIA
ntt
I know this might sound crazy but when I first got my Comptech Icebox and foam fliter from them, they forgot to send the filter oil with it. So I called up Comptech only to find out that this company called UNI actually manufactures the filter and the filter oil. They said they would send me the oil but in the meantime, I could just put a thin (I empasize THIN) coat of regular motor oil on the filter. So I got my oil pan, put just enough oil so that the whole pan was covered with a thin layer, and I rolled the filter in there. Worked like a charm.
[Modified by CPR, 10:18 PM 11/14/2001]
I talked to Comptech and they said that using K&N oil is fine. Did you know the K&N OIL is just mineral oil with red dye< and the cleaner is just laundry detergeant with lots of water>
Got this from the K&N website:
K&N air filter oil is a compound of mineral oil blended with special polymers to form a very efficient tack barrier. Red dye is added to show just where you have applied the oil. Eventually the red color will fade but the oil will remain and filter the air.
Yeah it looks like K&N filter oil will do, as will any other brand. I may be able to get Uni or Finer (an Australian brand) at some stores near my house. All good news.
ntt
ntt
does anyone have any more info on this? I can't get a hold of comptech. Thanks.
is this true???????? if so then i'm gonna stop buying the kits hee
Austin
Using oil for the motorcycle foam filters would be fine too - that is all the Uni stuff is really.
[edit] I meant to say "foam filter cleaners". you obviously can't use the motorcycle filters...
[Modified by Flux, 4:39 PM 11/20/2001]
If you only use it once Give me $5 and you send me yours and I will send you mine.
nEoMuGen
Mar 9, 2004 12:34 PM
reVVin
Jan 30, 2002 10:35 AM
