What Turbo Should I Get??
Old Jun 16, 2004 | 07:28 AM
integlspwr2k's Avatar
Default What Turbo Should I Get??
This is my power goals.
300HP on a B16 motor with 92 octante pump gas. Boosting 10-12lbs daily. It will have a After market intake manifold like JG, and cam gears. I am going to have one of the best tuners in hawaii tuning my car with uberdata.
What turbo do you guys reccomend? Also specs on the turbo like compressor size, exhuast size, and stage of the wheels.
Thanks In Advance!
Old Jun 16, 2004 | 08:25 AM
STHPERFORMANCE's Avatar
Default Re: What Turbo Should I Get?? (integlspwr2k)
Sc34
.63 rear
would be my guess
or
Sc61
.63 rear
i would go with the Sc61, It has mad potencial.
Old Jun 16, 2004 | 09:27 AM
bluebullet's Avatar
SC 34 .63 A/R is plenty for 300whp
Old Jun 16, 2004 | 10:45 AM
94gsr4dr's Avatar
Default Re: (bluebullet)
SC 50 .63 ar
Old Jun 16, 2004 | 11:03 AM
95GSRTT
Guest
Posts: n/a
Default Re: (94gsr4dr)
t77, blow that **** away!! lol
Old Jun 16, 2004 | 01:29 PM
JZ 97 SS 1500's Avatar
Default Re: (95GSRTT)
SC50, SC32, or SC34 is more then enough for your goal. Any of those units will do the job.
Jose
Old Jun 16, 2004 | 03:05 PM
TitanMotorsports.com's Avatar
Default Re: (JZ 97 SS 1500)
titan61 with .63 ar
at 8 psi on a b16 (rods, pistons, blockguard) we made 275 hp at the wheels
quick spool and room to grow with this turbo
Old Jun 16, 2004 | 04:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">t77, blow that **** away!! lol</TD></TR></TABLE>
haha that would be nice, but i need it to be reliable.
I forgot to mention, it is going to be a Stock Motor. No engine work besides the bolt on mentioned.
Anything from the Garret or Innovative turbo?
Old Jun 16, 2004 | 06:58 PM
95GSRTT
Guest
Posts: n/a
if money isnt an issue get one of the garrett GTR series. Faster spool and very efficient.
Old Jun 16, 2004 | 07:34 PM
.::Lee::.'s Avatar
Default Re: What Turbo Should I Get?? (95GSRTT)
Not to be a smart ***, but if you are going to have one of the best local tuners tune your car, why wouldn't you ask his opinion first and see what he would like to work with.
BTW, you'd have a hell of a time spooling an SC-61 with a stock B16.
Old Jun 16, 2004 | 07:57 PM
Muckman's Avatar
Moderator in Chief
a SC34 .63 AR 57 trim would be the BIGGEST turbo id choose for that power range. And anything smaller will give you faster spool.
Old Jun 16, 2004 | 08:30 PM
Default Re: What Turbo Should I Get?? (Ibiza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ibiza &raquo;</TD></TR><TR><TD CLASS="quote">Not to be a smart ***, but if you are going to have one of the best local tuners tune your car, why wouldn't you ask his opinion first and see what he would like to work with.
BTW, you'd have a hell of a time spooling an SC-61 with a stock B16.</TD></TR></TABLE>
That would be the best way but he isnt really into the new things that are out via turbo technology like the new stuff from innovative or percision.
Old Jun 17, 2004 | 08:43 AM
Anymore from other companies like Innovative or Garret?
Old Jun 18, 2004 | 08:28 PM
anyone else?
Old Jun 18, 2004 | 08:51 PM
94gsr4dr's Avatar
talk to arturbo he will set you up with what is best.
Old Jun 18, 2004 | 08:54 PM
AirWaveGT's Avatar
Default Re: What Turbo Should I Get?? (94gsr4dr)
im planning on going for 300whp and im going to get a sc50. its what arturbo recommended to me for my gsr.
Old Jun 18, 2004 | 09:15 PM
91civicDXdude's Avatar
get a holset turbo off one of those 5.9 turbo diesels. its bigger than your head and will take all of 10,000 rpm to spool 8 psi, but it will be MAD CRAZY TURBO POWERED YO
Old Jun 18, 2004 | 10:07 PM
npcanibus3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">Anymore from other companies like Innovative or Garret?</TD></TR></TABLE>
i thought precision's turbos were based on the new garrett's turbos just that percisions throw on there own wheel.
Old Jun 18, 2004 | 10:09 PM
Default Re: What Turbo Should I Get?? (npcanibus3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by npcanibus3 &raquo;</TD></TR><TR><TD CLASS="quote">
i thought precision's turbos were based on the new garrett's turbos just that percisions throw on there own wheel.</TD></TR></TABLE>
i thought it was the other way. percision uses Ball Bearing style blades with their own manifold casting ?
Old Jun 18, 2004 | 10:55 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by npcanibus3 &raquo;</TD></TR><TR><TD CLASS="quote">i thought precision's turbos were based on the new garrett's turbos just that percisions throw on there own wheel.</TD></TR></TABLE>
Why would they? I thought the wheel design was the best part about the GT series.
Old Jun 19, 2004 | 07:25 AM
npcanibus3's Avatar
Default Re: What Turbo Should I Get?? (rochesterricer)
i was told the best part of the gt turbo's that set it apart were the dual ball bearings. yeh the wheels are kewl, but the ball bearings what spins it so well. companys such as atp and percision are there distributors. if you look at the atp/garrett turbos, they utilized most of the turbo, but in some cases, they modify the turbo with a brand new housing. Check it out at turbosbygarrett.com.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">
Why would they? I thought the wheel design was the best part about the GT series.</TD></TR></TABLE>
Old Jun 19, 2004 | 07:46 AM
npcanibus3's Avatar
http://www.superstreetonline.c...turbo/
95BlkGSR
May 19, 2009 04:47 PM
SmoKez
May 13, 2009 05:59 PM
civicjordan084
Oct 20, 2005 11:34 AM
turbohf
Mar 14, 2003 08:28 AM
boostedel
Nov 27, 2002 05:36 PM
