Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Torn boots from Beverun
Old Jun 16, 2004 | 03:49 AM
rex_boy's Avatar
Default Torn boots from Beverun
I tore a couple axle boots in my Hybrid CRX at Beaverun. The passenger outside and driver side inside. I don't run a lot of camber in the front about 1 1/4 because of fear that I will breaks axles. These have been on for 4 years without out a problem. My question is why would I tear boots like this? Is it because I was using all of the curbs and there was enough suspension travel that the boots got caught in the joint? I disassembled them and They still had a lot of grease in them and it wasn't all dirtier or anything so I am planning to rebuild them since I already have the tools and built them to begin with.
Old Jun 16, 2004 | 05:09 AM
philstireservice's Avatar
Default Re: Torn boots from Beverun (rex_boy)
4 years is a long time....probably dried out from age. The axles go through quite alot during an event.....good thing you are going to change them
Old Jun 16, 2004 | 01:30 PM
rex_boy's Avatar
Default Re: Torn boots from Beverun (Maxx44)
They really weren’t that worn. The car sits in the garage pretty much and is only driven to autox events and trailered to the track.
The track is really bumby coming out of turn seven and I was getting what a best can best describe as wheel hop. I not sure if it was the curbs or possible the wheel hop. I would like to know so I can try to avoid this situation next time. Any help would be appreciated.
Thanks,
Paul
Here is a picture. Sorry if its kinda blurry.
http://www.we-todd-did-racing....D.jpg
Old Jun 16, 2004 | 02:10 PM
h22avid's Avatar
I still think it may be age and just plain ol' normal wear.
You say it sees a lot of garage time and that can actually help to essentially dry rot the boot since more of its time is spent sitting dormant; it doesn't get the routine exercise that a boot on a daily driver gets to keep it flexible.
I'm guessing that it stiffened and dried a bit by not being used so much that when you got it out there in somewhat enduring conditions, the boot just ripped when stretched/flexed. How often and closely do you examine their condition?
It sounds like the axle itself is perfectly fine though since it still has plenty of good clean grease packed in it. If this is the first sign of wear, I say reboot and you're ready to go again
Modified by h22avid at 7:29 AM 6/17/2004
Old Jun 17, 2004 | 08:29 AM
SM 30 Hatch's Avatar
this happened to me after my event at beaverun as well.
Old Jun 17, 2004 | 04:45 PM
Outsane's Avatar
Default Re: (SM 30 Hatch)
gotta love Autozone lifetime warranty axles!
vu337
Feb 23, 2009 06:31 PM
GPoodle
Dec 5, 2003 03:07 PM
PilotSH
12
Sep 30, 2003 11:22 AM
brian estrada
Apr 16, 2003 03:04 PM
echo999
Jul 10, 2002 01:52 PM
