tokico adj. shocks
Old Jun 15, 2004 | 08:47 PM
tolstiy1980's Avatar
Default tokico adj. shocks
i just lowered my gsr and i put eibach sportlines with tokico adj. shocks.
can anybody tell me what to set it to? so i wouldn't oversteer or understeer.
Old Jun 15, 2004 | 09:06 PM
Sack Master's Avatar
Default Re: tokico adj. shocks (tolstiy1980)
Just play with it and figure out which feels best on your car. I have mine at 2 front 3 rear.
Old Jun 15, 2004 | 09:13 PM
Default Re: tokico adj. shocks (Sack Master)
mine set at 3 on the front and back right now
Old Jun 15, 2004 | 09:17 PM
..::91TEG-G2::..'s Avatar
alright bro.. this is what u do,
if u bought them brand new in box, theres a paper in there that show's the adjustments, and installation info,
and it's goin to tell u exactly what ima tell u now.., so u can go back for referance if ur not sure, but it says this
in order to have no oversteer or understeer, set the shocks to the same number on all sides, and it says which side (front/rear) to set at a higher/lower number to get understeer and oversteer.
and it also says to not have different settings on left to right sides (ie. left side on 3, right side on 1)
hope that helps, and like i said, just look on that sheet, it tells you everything
Old Jun 15, 2004 | 10:59 PM
PlastikOwl
Guest
Posts: n/a
Default Re: tokico adj. shocks (..::91TEG-G2::..)
same setup here... 5 on all corners
Old Jun 16, 2004 | 12:31 AM
Default Re: tokico adj. shocks (PlastikOwl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl &raquo;</TD></TR><TR><TD CLASS="quote">same setup here... 5 on all corners </TD></TR></TABLE>
how's your kidneys feel at the end of the day?
92db2gs-r
Feb 22, 2011 04:06 PM
ShinotakuX
Suspension & Brakes
Aug 31, 2007 11:19 AM
AcuraKid
Suspension & Brakes
Jun 4, 2005 05:25 AM
FirstAdition1
Dec 2, 2003 07:22 PM
joeseph
Dec 5, 2002 11:13 AM
