clutch question
Old Jun 15, 2004 | 07:35 PM
phatrick2332's Avatar
Default clutch question
Just put a clutch in the hatch, motor is still out of the car, but when i move the lever up, and i mean yank on it, it moves like 3/4 of an inch, how far should it move normally. Maybe the bolts are torqued to much, and the fingers are pushed in to far on the Pressure Plate?
thanks
pat
Old Jun 15, 2004 | 08:40 PM
EL Vap133's Avatar
Default Re: clutch question (phatrick2332)
What lever are you talking about?
Old Jun 16, 2004 | 05:18 AM
the lever that the actual cable attaches to. The pressure plate fingers are about..3/4 on an inch from the splined part of the disk, normal?
I think im just worrying
Old Jun 16, 2004 | 05:44 AM
1st-hybrid's Avatar
Default Re: (phatrick2332)
I think you're worrying too much as well.
The likely hood of over torquing the 12mm bolts is aways there, because they only need like 9ft lbs, you wouldn't get the PP any closer by doing so.
The lever does not move that much, I'm not sure the exact distance it moves, but it's not great.
99h22ek
Aug 19, 2006 05:04 PM
n.e.coupe
Oct 13, 2005 05:53 AM
Nextelbuddy
Jun 19, 2003 06:37 PM
