bad gas mileage...please help.. $50week on gas is killin me!!
on my beater, a 96 buick, 140,xxx miles.. i use to get 300+ miles on a full tank of gas. my tank is 16gallons. now am getting 220.. what could cause a car to do this? i changed the oil, air filter, cleaned the injectors.. what else
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jokerluv »</TD></TR><TR><TD CLASS="quote">fuel filter</TD></TR></TABLE> god i hope ur rite!!! but 1st i got 2 find it!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote"> god i hope ur rite!!! but 1st i got 2 find it!!</TD></TR></TABLE>
A clogged fuel filter SHOULD also result in a noticeable loss in power.... Its easy to change out though, so try it out and see what happens. Could also be the O2 sensor failing, which I would suspect before the filter...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jokerluv »</TD></TR><TR><TD CLASS="quote">fuel filter</TD></TR></TABLE>Or any of 100 other tune-up type things. Fouled spark plugs? Bad plug wires cap & rotor (arcing)? Spark timing way off? Plugged cat? Bad O2 sensor? Dragging brakes? Suspension alignment? Flat tires? Auto-trans starting to mess up? The possibilities are endless. Tune-up first, because that stuff can hide a real problem with misleading symptoms.
I really doubt it is tune up stuff. That will cause the milage to drop off slowly. A plugged fuel filter will not cause it, it would make your mileage a little better but power to be off because of running lean. Sounds like a fuel pressure regulator, tranny problem (no overdrive), plugged exhaust, malfunctioning thermostat (engine not running warm enough) or maybe a bad mass air flow sensor. As you can see, there are many things that can cause it, and you are never gonna fix it by just aimlessly replacing parts.
