which is the top piston ring
Old Jun 15, 2004 | 05:19 PM
6shootahorsenamedtrigga's Avatar
Default which is the top piston ring
Okay I am about to check ring-end gap. The machine shop set the to stock specs but I want to double check. How do you know which ring is the top. These are oem .25mm over rings for a b18b1. The only difference I can see between the first and second rings is one outside edge is silver and the other is dark like the ring. So which one is the top.
Old Jun 15, 2004 | 05:28 PM
Default Re: which is the top piston ring (mphinesee)
Never mind...I found the answer : the top is the thickest one.
Turbo B18C EJ6
Jul 19, 2012 04:49 PM
4DRmafia
Apr 17, 2009 08:49 PM
rocket_R
Jun 13, 2006 11:11 PM
Pengo
May 22, 2004 12:05 PM
