B17a sensors, etc. on b18c1
Old Jun 15, 2004 | 01:09 PM
db2integra's Avatar
Default B17a sensors, etc. on b18c1
I am purchasing a B18c1 bare block. Will the ODB1 sensors, etc. from my b17a1 bolt right up?
Also, will the b17a oil pan fit?
Edit: B17a block is for all intensive purposes exactly the same as a b16 odb1 block.
Thanks
Modified by db2integra at 1:25 AM 6/16/2004
Old Jun 15, 2004 | 04:24 PM
db2integra's Avatar
Default Re: B17a sensors, etc. on b18c1 (db2integra)
TTT
Old Jun 15, 2004 | 06:31 PM
db2integra's Avatar
Bump
Old Jun 15, 2004 | 06:33 PM
B16A1-EF9's Avatar
All the sensors should work fine. There is no difference in the sensors.
I'm not sure about the oil pan, I believe that the b18c oil pan is different.
Old Jun 15, 2004 | 07:07 PM
mmuller's Avatar
Mad Scientist
Default Re: B17a sensors, etc. on b18c1 (B16A1-EF9)
yep, sensors will fit; oil pan wont
Old Jun 15, 2004 | 09:22 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db2integra &raquo;</TD></TR><TR><TD CLASS="quote">I am purchasing a B18c1 bare block. Will the ODB1 sensors, etc. from my b17a1 bolt right up?
Thanks
Modified by db2integra at 1:25 AM 6/16/2004</TD></TR></TABLE>
A B17 IS a B16, just diffenrent crank, rods, pistons.... Yes, the sensors will work fine. No, the oil pan will not work. You will need a B18C oil pan to clear the B18C main cap girdle.
DA TeG 90
Nov 8, 2009 06:14 AM
jchrm80
Jan 18, 2009 09:59 AM
CATCH DIS HATCH
Apr 4, 2004 09:15 PM
yellow blur
May 28, 2002 05:21 PM
dho311
Apr 19, 2002 08:57 AM
