Fan Replacement B16 swap WTF!?!
Old Jun 15, 2004 | 12:55 PM
6MTV6's Avatar
Default Fan Replacement B16 swap WTF!?!
I need to upgrade my radiator cooling fan since I have a b16 and my A/C fan had to be pulled out for the header clearance. Now the Radiator fan is pulling double duty as both radiator fan and A/C fan.
I have A/C and live in Phx. It's 106 degrees out as I write this. When I'm sitting I overheat. With my windows down, I melt.
I figure if I double the CFM of the stock fan, it should offset the lack of the A/C fan.
How big of a fan should I use? <U>What's the CFM pulled by the stock radiator fan?</U>
Anybody w/ a B16 please help!
Old Jun 15, 2004 | 01:31 PM
91civicEX's Avatar
Default Re: Fan Replacement B16 swap WTF!?! (Bishop4G)
why dont u get a smaller ac fan? my friend with a b16 got some tiny ac fan and mounted it on the other side of the radiator. ill let him know
Old Jun 15, 2004 | 02:02 PM
slowpokesi's Avatar
Default Re: Fan Replacement B16 swap WTF!?! (91civicLX)
get a small pusher ac fan and put it on the opposite side of the radiator, wire it into the ac fan connector,
Old Jun 15, 2004 | 02:09 PM
6MTV6's Avatar
Default Re: Fan Replacement B16 swap WTF!?! (slowpokesi)
To get the same cooling that a pull fan provides, a push fan needs to be at least 1/3 stronger than the pull fan it's replacing.
There's also not much clearance on the front side of the radiator. Anybody got an idea what size fan I could fit on the front of the radiator in front of the header side?
Old Jun 15, 2004 | 03:47 PM
ham's Avatar
ham
put in a 180 thermostat and get the relay so the fan comes on at a lower temp and it will never get hot. i wired my fan straight to the dizzy so its on all the time, yes i know its ghetto.
Old Jun 15, 2004 | 04:30 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bishop4G &raquo;</TD></TR><TR><TD CLASS="quote">
This is what i would like to know as well.
Old Jun 15, 2004 | 06:32 PM
sleepster's Avatar
Default Re: Fan Replacement B16 swap WTF!?! (fourthgenhatchB17)
This is what I did, its better than nothing.
Bought a spal fan from EBAY. (http://www.spalusa.com/) The 7.5 inch fan,
only 2.05inch in thickness.
Or get a push fan like someone said and mount in front of radiator / condensor.
Works good!
Old Jun 16, 2004 | 01:06 PM
6MTV6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
BUMP. I need to know how much CFM I have so I know what fan to get.
Old Jun 17, 2004 | 06:32 AM
6MTV6's Avatar
BUMP.
Old Jun 17, 2004 | 07:21 AM
ham's Avatar
ham
i know its not pulling any more than 1500cfm, so just get one that is even better for sure.
Old Jun 17, 2004 | 07:27 AM
6MTV6's Avatar
Default Re: Fan Replacement B16 swap WTF!?! (zcnos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcnos &raquo;</TD></TR><TR><TD CLASS="quote">i know its not pulling any more than 1500cfm, so just get one that is even better for sure.</TD></TR></TABLE>
Do you know what the amp draw of the standard fan is? I don't want to blow fuses back and forth.
Old Jun 17, 2004 | 03:28 PM
Do you know what the amp draw of the standard fan is? I don't want to blow fuses back and forth.</TD></TR></TABLE>
Dang, ur takin the questions right out of my mouth. BUMP for this question. I dont feel like using my meter...
Old Jun 18, 2004 | 07:21 AM
6MTV6's Avatar
Dang, ur takin the questions right out of my mouth. BUMP for this question. I dont feel like using my meter...</TD></TR></TABLE>
FOCK! It looks like I have to go buy a multi-meter. I wan't a new fan...
Old Jun 18, 2004 | 10:09 AM
6MTV6's Avatar
Bump Fockers.
I know one of you wiring gurus know how much amp draw the stock radiator fan is.
Old Jun 21, 2004 | 02:15 PM
6MTV6's Avatar
BUMP it up.
I need to know what the standard radiator amp draw is. I know the AC condensor fan runs on a 15A fuse, I don't know which fuse is for the radiator fan.
Please help me out guys. It's about 105 degrees out right now.
Old Jun 21, 2004 | 02:26 PM
Magnum000's Avatar
I have a B16 installed in my CRX also w/AC connected. I bought a new bigger radiator and installed a 12" slim line puller fan and then in front I installed a 10" pusher fan (w/a few bending of pieces it fits). Both fans I got at summit and used the plugs already there from stock fans w/no power issues at all and no overheating problem at all. Thfans cost about $60-70 nad I got an aluminum KOYO 3" radiator at absoluteradiator.com for $300ish. Maybe pricey but I do not want to ruin my engine and I am now enjoying AC with NO PROBLEMS!!!!!!!!!
Old Jun 21, 2004 | 02:44 PM
b16_madman's Avatar
Default Re: Fan Replacement B16 swap WTF!?! (Magnum000)
I'm assuming you're using hasport billets? I ran all their stuff w/the a/c and all for a long while w/my stock manifold and it all fit. The ratiator is a stock sized full metal one from 1-800-radiators.com or somethin like that.
But when I say it fit that meant the manifold cover touched the a/c fan, but it didn't cause any problems. No pic, but you get the idea.
But then again, I'm only in GA where its in the 90's. It's h t
Old Jun 22, 2004 | 07:02 AM
6MTV6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magnum000 &raquo;</TD></TR><TR><TD CLASS="quote">I have a B16 installed in my CRX also w/AC connected. I bought a new bigger radiator and installed a 12" slim line puller fan and then in front I installed a 10" pusher fan (w/a few bending of pieces it fits). Both fans I got at summit and used the plugs already there from stock fans w/no power issues at all and no overheating problem at all. Thfans cost about $60-70 nad I got an aluminum KOYO 3" radiator at absoluteradiator.com for $300ish. Maybe pricey but I do not want to ruin my engine and I am now enjoying AC with NO PROBLEMS!!!!!!!!!</TD></TR></TABLE>
Thanks man I'll do that.
ScubaNole
Sep 12, 2019 08:37 AM
milkypros
Aug 10, 2011 03:17 PM
Protoss
Mar 17, 2006 01:09 PM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
JBBNJ609
Nov 28, 2003 02:13 PM
