front crossmember torque specs?
this is the only thread i've found concerning this:
https://honda-tech.com/zerothread?id=673445
i was wondering if anyone knew the EXACT torque spec for the 4 front cross member bolts and the bolts where the radius rod connects to the front LCA.
thanks guys
thanks guys
Rehashing an old one - but I have found two other posts dating to 2003 with no particular answer besides, "just past snug". I am bolting up a new Full-Race crossmember and don't have a Helms. Does anyone have the torque specs for the tow hook bolts and crossmember bolts? Thanks.
I believe the front crossmember bolts are torqued to 32 ft lbs and the same for the radius rod to the lower control arm. And you wont be able to torque the radiuse rod because you cant fit a torque wrench in there(unless you have the smallest torque wrench known to man) so just feel 32 ft lbs. with your arm. lol
