will a b18b throttle body fit and work properly on a b16a in a 91 civic hatch
will this work, i had to get a b18b throttle body instead because i couldnt find a b18a, so will this work ? all i see difference is that the b18b has a map sensor on the actual throttle body
The bolt pattern is the same. But the opening might not line up correctly.
I had an issue with one that had an extra hole towards the bottom and it leaked bad so I could not use it.
You could try it, it doesn't take long at all to put it in.
**** you gotta be kidding me man,,, so i cant evn use it ;( ****, i knew it, looks like i'll have to get a b18a now.. FFS **** me off
No that's not what I am saying.
"I" had a problem with one a while ago. It might very well fit.
As I said, just try it on the manifold. I think the chances of it working are greater than not.
sweet :0 60mm as compared to 58 mm = more air :D = more quicker b16 :d
chineseflyrice
Jan 23, 2007 07:06 AM
