last distributor question, help me before i spend lotsa $$...
Old Jun 15, 2004 | 09:54 AM
SI_niki's Avatar
Default last distributor question, help me before i spend lotsa $$...
ok i need help, before i go spend hella money on a new disty, i needta know if you guys think buying it will fix my problem. jdm b16 swap into 93 delsol si, cars cranking, but still not starting. i turned the disty 180, grounds grounded, wiring + plugs good, ecu good, batterys ok, set timing, got fuel, air and spark, <U>but the spark is orange</U>. i read in HT it has to be blue to start. what would make it orange? bad disty/coil/ignitor? if i replace it you think my carll start finally? if it was ecu or wiring would it even spark? PLEASE PLEASE HELP!!
Old Jun 15, 2004 | 09:56 AM
93CivicSI's Avatar
Default Re: last distributor question, help me before i spend lotsa $$... (SI_niki)
Orange spark means low temp spark - I would look at your Coil - however coil and and igniter tend to go out together - OR - one will hurt the other.
Old Jun 15, 2004 | 10:05 AM
SI_niki's Avatar
Default Re: last distributor question, help me before i spend lotsa $$... (93CivicSI)
thank you, thank you, thank you! hopefully after this my car will finally start! any one else? still taking suggestions, tips ect. just incase!
hondachris1994
Aug 15, 2017 10:58 AM
egluism33
May 25, 2008 06:17 PM
dboz3403
Sep 20, 2007 11:03 PM
keng
Jul 6, 2005 07:27 AM
widecoupe
May 12, 2002 11:26 AM
