H22A into a 95 Accord EX (SOHC VTEC)
Old Nov 14, 2001 | 11:48 AM
lsvtec's Avatar
New User
Default H22A into a 95 Accord EX (SOHC VTEC)
My friend and I are setting up to swap an H22A (with 5spd) into a 1995 Accord EX Sedan (had a F22A SOHC VTEC with a 5spd) this weekend. I want to know of any hitches that anyone has run into with this swap. I did a search and found the distributor issue, but it was into a car that is one gen older than the one we will be working on so I am not sure if it applies. Any info would be appreiciated. Thanks in advanced guys.
Old Nov 14, 2001 | 01:07 PM
Greyout's Avatar
Default Re: H22A into a 95 Accord EX (lsvtec)
if you went with a JDM motor, you will want to keep the following from the US-spec fuel rail & ignition setup.
[Modified by JDM LUDE, 10:07 PM 11/14/2001]
Old Nov 14, 2001 | 01:10 PM
lsvtec's Avatar
New User
Default Re: H22A into a 95 Accord EX (JDM LUDE)
Thanks for the reply.
Yeah, we bought the JDM motor. Why will the fuel system off of the JDM motor not work?
I have been told that the header on the JDM H22A will not line up with the exhaust on a 1995 Accord, not in length but left to right, is there any validity in this? It sounds a little far fetched to me.
[Modified by lsvtec, 3:10 PM 11/14/2001]
Old Nov 14, 2001 | 01:24 PM
LoudAccord's Avatar
no header will fit... you have to cut about 1 foot off and weld the flange back on. use the prelude header, and cut the foot off from that, and weld the accord flange on to the lude header.
Rzinzow01
Oct 16, 2017 05:48 AM
socialistic
May 14, 2008 04:28 AM
pwr5hift27
Oct 28, 2002 11:17 AM
