which tranny to go with? Rebuild or upgrade?
Old Jun 14, 2004 | 09:16 PM
charliebrown1320's Avatar
Default which tranny to go with? Rebuild or upgrade?
I'm looking for some good advice. B16 JDM LSD tranny took a dump (havent opened it up yet) what to go with next? the car is a full weight 95 Integra about 300 WHP for now (built / boosted LS vtec) street tire racing often, Bogart wheels M&H slicks once a month, Clutch masters stage 4 clutch (sprung hub, 4 puck)
The low gears are nice but I've heard that the differentials arent as strong as the LS ones, is this true?
How much more of an RPM drop should I expect between shifts because of gear ratio spread?
Whats the wiser thing to do?
Rebuild, replace (how much power and torque can these things usually take?)?
Send out to get upgraded ( who can do this, what does it cost what exactly can I expect)?
Go with an LS tranny and install a Phantom grip LSD?
Old Jun 15, 2004 | 12:11 PM
Default Re: which tranny to go with? Rebuild or upgrade? (charliebrown1320)
is there anyone who really knows their **** on these trannys?
Old Jun 15, 2004 | 10:17 PM
slow down, not all at once, I cant read all these replies that fast.
Ok, just one question then. Who can I get in touch with that specializes or knows their **** on Honda trannies?
Old Jun 16, 2004 | 07:36 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charliebrown1320 &raquo;</TD></TR><TR><TD CLASS="quote"> The low gears are nice but I've heard that the differentials arent as strong as the LS ones, is this true?
not true...b16 and ls trannys have the weakest stock diffs.; but they are all weak...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charliebrown1320 &raquo;</TD></TR><TR><TD CLASS="quote"> How much more of an RPM drop should I expect between shifts because of gear ratio spread?
between what tranny's? ls and b16? go here for a nice gear ratio/speed calculator
http://www.team-integra.net/se...s.asp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charliebrown1320 &raquo;</TD></TR><TR><TD CLASS="quote"> Rebuild, replace (how much power and torque can these things usually take?)?
Go with an LS tranny and install a Phantom grip LSD?</TD></TR></TABLE>
Its all about your driving...you drive them nice they can take lots of power...you cant drive, well they'll break.
depending on what wrong with your tranny i would fix whats wrong with it.
phantom grip?NO they are not meant for drag and it will wear out you diff.
add a quaiffe and have no more problems..
Old Jun 16, 2004 | 10:38 AM
Default Re: which tranny to go with? Rebuild or upgrade? (mmuller)
thank you.
sahwan
Transmission & Drivetrain
Oct 3, 2012 01:48 PM
bb6kid22
Oct 20, 2010 03:16 PM
DARKTEG_
Aug 9, 2006 02:07 PM
dxhatch1993
24
Aug 16, 2004 06:14 PM
