daiyama lug nuts - the lightness, y0!
Old Jun 14, 2004 | 07:19 PM
magic hat #9's Avatar
Default daiyama lug nuts - the lightness, y0!
i picked up these nice lugnuts from bluer tonight. you can see the obvious weight advantages. they are also open ended for extended studs and have a knurled end to help get them on/off by hand. if you want them, im bluer and he'll hook you up.
da stock
locking lugnut
mcgard lugnuts from summit, big black bitches!
daiyama sweetness
the product
Old Jun 14, 2004 | 07:21 PM
Default Re: daiyama lug nuts - the lightness, y0! (magic hat #9)
red x! oh well, you'll have to wait until wee-todd gets moving again.
the cliff notes: stock lugnuts = 30g, stock locking nuts = 52g, daiyama = 22g
Old Jun 14, 2004 | 07:28 PM
Padawan's Avatar
Darth ModerVader
Are they tapered-seat, or stock "acorn" style? If they're tapered, they shouldn't be used with stock Honda/Acura wheels.
From what you described, they do sound nice though, and of course there's the ~ 1/3 lb. total weight reduction.
Old Jun 14, 2004 | 07:38 PM
Mr.Fairlady's Avatar
how much(even though I can't see ****)---and are the Acorn?? COLORS?
Old Jun 14, 2004 | 07:42 PM
George Knighton's Avatar
H-T Order of Merit
Well, I used to have a set of Daiyama on my ITR.
Somebody "borrowed" them for his race car and I haven't seen them since.
Old Jun 14, 2004 | 07:44 PM
Default Re: daiyama lug nuts - the lightness, y0! (Mr.Fairlady)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Fairlady &raquo;</TD></TR><TR><TD CLASS="quote">how much(even though I can't see ****)---and are the Acorn?? COLORS?</TD></TR></TABLE>
they are conical and only for use with aftermarket wheels (with conical seats). the lugnuts are "titanium gold," otherwise known as gunmetal.
it's strange because the pictures show up fine on wee-todd but not here
Old Jun 14, 2004 | 08:11 PM
.RJ's Avatar
.RJ
I have the skunk2 lugs, which are pretty similar.
I impact them off all the time, never a problem.
Old Jun 14, 2004 | 11:53 PM
SpoogenJay's Avatar
i like them so much i might get another set
Old Jun 15, 2004 | 12:15 AM
itr1244's Avatar
Default Re: daiyama lug nuts - the lightness, y0! (HybridTypeR80)
ok.. i need some pics or so link to pics
Old Jun 15, 2004 | 12:55 AM
H-T Order of Merit
Default Re: daiyama lug nuts - the lightness, y0! (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I have the skunk2 lugs, which are pretty similar.</TD></TR></TABLE>
Come to think of it, he's run off w/my Skunk2 lug nuts, too.
Old Jun 15, 2004 | 01:04 AM
uNF$@#!'s Avatar
Default Re: daiyama lug nuts - the lightness, y0! (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Are they tapered-seat, or stock "acorn" style? If they're tapered, they shouldn't be used with stock Honda/Acura wheels.
From what you described, they do sound nice though, and of course there's the ~ 1/3 lb. total weight reduction. </TD></TR></TABLE>
1/3 lb total rotational weight reduction! ... what is that...actual 1lb dead weight loss?
Old Jun 15, 2004 | 03:57 AM
Padawan's Avatar
Darth ModerVader
Default Re: daiyama lug nuts - the lightness, y0! (Captain Commando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captain Commando &raquo;</TD></TR><TR><TD CLASS="quote">
1/3 lb total rotational weight reduction! ... what is that...actual 1lb dead weight loss? </TD></TR></TABLE>
Located that close to the center of rotation? Probably less.
Old Jun 15, 2004 | 04:39 AM
Located that close to the center of rotation? Probably less. </TD></TR></TABLE>
think weight savings + longer lug nut to bite onto more stud threads + open ended for longer studs + sweet color = the shizzy, y0!
Old Jun 15, 2004 | 05:03 AM
H-T Order of Merit
If you are after these and trying to decide, I'd get the Daiyama before the Skunk.
The Daiyama have a very definite and easy to use grippy area that makes them easier to get on and take off than the Skunk2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">longer lug nut to bite onto more stud threads + open ended for longer studs </TD></TR></TABLE>
Well, you won't bit into more stud threads unless you have longer studs.
If you get longer studs, you do introduce some other issues. A Porsche instructor talked me into getting longer studs for the ITR, and cited a couple of valid reasons.
You never stop to really think about things like this, but the advantages of having the longer studs for the average recreational track user is offset by how much longer it's going to take to change your wheels.
Moreover, since a lot of us resort to power tools of some kind in this event, your power tool will cause the lug nut to continue to put pressure on the extended stud as you wind it off and wind it on.
This causes a gradual stripping of the threads of whichever item has the softer metal (lug or lug nut) and you will eventually find yourself with a frustrating experience if you're not very careful.
Also, when you find yourself graduating to a racing class (for those few of us who intend to do that), you will be asked questions if your lug nuts do not entirely cover the studs. It's considered an additional safety problem in some series.
I had extended studs (Skunk2) and extended lug nuts (Skunk2 and Daiyama) last season.
It was just too much trouble, and since the car was going to be in the shop for a long time anyway, we switched back to shorter studs and regular lug nuts.
We do not feel especially slower as a result.
Old Jun 15, 2004 | 05:10 AM
MattD@Stoptech's Avatar
Default Re: daiyama lug nuts - the lightness, y0! (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
I find that reasoning a bit dubious. The winding/unwinding of the lugnut shouldn't put any significant stress on the stud (as long as the threads are clean.) Was this just a theory, or has this ever happen to anyone?
Matt
Old Jun 15, 2004 | 05:46 AM
H-T Order of Merit
Default Re: daiyama lug nuts - the lightness, y0! (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
Matt</TD></TR></TABLE>
Yes, it happened to me. You're right that winding/unwinding by hand doesn't put much pressure on the studs.
However, after a while, the kids will talk you into investing in power equipment, and I theorise that what caused the problems is that they could not use the power tool to take the lug nuts straight on and off the way you would by hand.
I think that the power tool would put undue pressure on the studs as the lug nuts were put on and taken off, until the threads were damaged enough to make putting on and taking off the lug nuts a problem.
Corey witnessed this...you can ask him what he thinks caused it, but that's what I think.
Good job always questioning, Matt. A lot of weird theories get spread around Honda Tech without any real proof or even evidence.
Old Jun 15, 2004 | 05:52 AM
nEoMuGen's Avatar
About time you hopped on the bandwagon, 1 out of every 2 R-Speed guys have them. TDM &lt;Taiwan Domestic Model&gt; g00dness!
Old Jun 15, 2004 | 05:53 AM
Good job always questioning, Matt. A lot of weird theories get spread around Honda Tech without any real proof or even evidence. </TD></TR></TABLE>
What kind of power t00l are we talking about here? Were the lugnuts started by hand? Were the threads clean? What stripped, the lugnuts or the stud?
-Matt, who is full of questions today
Old Jun 15, 2004 | 06:34 AM
H-T Order of Merit
What kind of power t00l are we talking about here? </TD></TR></TABLE>
Some kind of electric impact thing. It was expensive. High voltage battery so it can be used at events.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Were the lugnuts started by hand?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> Were the threads clean? </TD></TR></TABLE>
Sometimes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What stripped, the lugnuts or the stud?</TD></TR></TABLE>
It must've been the studs, because Corey is still using my Daiyama and Skunk2 lug nuts and he's not complaining.
Old Jun 15, 2004 | 07:46 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it happened to me. You're right that winding/unwinding by hand doesn't put much pressure on the studs.
I think that the power tool would put undue pressure on the studs as the lug nuts were put on and taken off, until the threads were damaged enough to make putting on and taking off the lug nuts a problem.</TD></TR></TABLE>
GK, I think the problem is the stud quality, not them being longer.
The Skunk2 studs are junk. I broke 3 out of 5 in one hub. I ended up getting the Spoon stronger and 10mm longer studs and never have a problem since.
My poor lug nuts:
Old Jun 15, 2004 | 08:09 AM
Default Re: daiyama lug nuts - the lightness, y0! (Wai)
i use a lower power cordless drill to take the lugnuts off/on. it's so underpowered i must break the lugnuts loose and i always torque them properly. no stud problems, although i do now have arp studs.
can anyone host the lugnut pictures for me? i can email them right over, thanks!
Old Jun 15, 2004 | 12:01 PM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks. I never even looked at Spoon, but I'll do that next time I want longer studs.
Old Jun 15, 2004 | 12:16 PM
.RJ's Avatar
.RJ
FWIW, I'll be picking up some longer OEM (Acura TL Rears) studs this winter.
Old Jun 15, 2004 | 12:42 PM
Wai's Avatar
Wai
Thanks. I never even looked at Spoon, but I'll do that next time I want longer studs. </TD></TR></TABLE>
Unfortunately Spoon has discontinued those a while ago....
However, johng found a really good alternative OEM part that sure exceeds the quality of the Skunk2 studs (previsouly called Z-Speed) --- TL rear studs as .RJ mentioned:
https://honda-tech.com/zerothread?id=244036
Modified by Wai at 3:57 PM 6/15/2004
Old Jun 15, 2004 | 12:50 PM
.RJ's Avatar
.RJ
ARP studs are really nice also - they've got a non-threaded portion at the end of the stud that makes it much easier to get the lugs on.
