Does the front bumper of a 2dr fit in a 4 dr??
Old Jun 14, 2004 | 06:37 PM
Pablo's Avatar
Default Does the front bumper of a 2dr fit in a 4 dr??
Hi, I'm from Argentina. This is my first post. I own a Civic 4 dr 1993 made in Japan.
My question is if the front bumper of a Civic coupe fits in my 4 dr. Do I have to modify something ???
Thanks.
Old Jun 14, 2004 | 06:38 PM
Luserkid's Avatar
Default Re: Does the front bumper of a 2dr fit in a 4 dr?? (Pablo)
This topic has been agrued alot. But final answer (from what i understand) is that you need to mod it.
Old Jun 14, 2004 | 06:47 PM
dogfood's Avatar
there was a great post on this with alot of pics so do a search and it will let you decide whether its worth the time or not, good luck and welcome to HT
Old Jun 14, 2004 | 06:53 PM
Discosteak's Avatar
it fits but some things are off ill see if i can find the thread
Old Jun 14, 2004 | 07:01 PM
Deemeetree's Avatar
Electrician
Supposedly if you mount a 2DR/3DR front bumper, you'll also need the corner lenses.
Old Jun 14, 2004 | 07:03 PM
Pablo's Avatar
I'v recently done a search, and I found: https://honda-tech.com/zerothread?id=880954
I really dont understand what things I have to modify, because, some only modify the hole that holds the bumper to the fender, and other the fender, corners and something else. I NEED HELP!!
Old Jun 15, 2004 | 08:18 AM
Pablo's Avatar
Any suggestions???
Old Jun 15, 2004 | 08:41 AM
handa's Avatar
Here is what i've learned so far (maybe not accurate):
2DR compared to 4DR
-corners are shorter in length
-hood is shorter near the headlight placement
-bumper is also shorter near the fender wells
-fenders will not fit 4DR corners, either shorter/longer in length...not sure
With the 4dr stock, you can replace to 2dr front bumper, corners, and fenders...and the hood is no biggy, but you'll have a pinky gap between the hood and headlights. Also the bumper will be short near the fender wells:
do you see the bumper? it's quite shorter:
With modifications to the bumpers & fenders, you can actually just drill holes on them where the screws go and stretch it to fit where you need it.
I've also heard people combine 2dr & 4dr fenders together. ie. they cut and weld half of the fenders together, etc.
With modifications YOU WILL MAKE IT FIT!!!!!
I hope this helps! I'm doing this sometimes myself.
ch3xy
Honda Civic (2006 - 2015)
Aug 19, 2010 12:33 PM
sbarmann
Mar 23, 2008 06:06 PM
Rocco.
Jan 17, 2005 08:23 AM
8o8da9speed
Jul 5, 2004 03:43 PM
.ShawnD.
10
Oct 18, 2002 07:24 AM
