How much does the US spec ITR weigh?
Old Nov 14, 2001 | 10:34 AM
Pillesnoppen's Avatar
New User
Default How much does the US spec ITR weigh?
As the heading says... I just wonder what the "official" weight is as seen in Acura's materials. I have a UK spec ITR and the weight is quoted at 1101 kg(2425lbs).
This is without air con. Just wondering if there's a difference in weight...
Old Nov 14, 2001 | 10:47 AM
sackdz's Avatar
Default Re: How much does the US spec ITR weigh? (kussimurran)
I weighed mine on a truck scale here at work recently.... 2540 lbs. with 3/4 tank of gas, carbon hood, and AC, does anyone else have a 97 with A/C !?!?!?
Old Nov 14, 2001 | 10:59 AM
Willard's Avatar
My car was 2525lbs. with a/c low tank of gas.
Will
Old Nov 14, 2001 | 11:14 AM
Mike K's Avatar
Default Re: How much does the US spec ITR weigh? (Willard)
Before: stock, with full tank o' gas 2550 w/o me, 2790 w/me
After putting myself and my car on a diet, 2320 w/o me, 2540 w/me
Let's just say the car gets up and goes. Weight makes SUCH a difference.
Old Nov 14, 2001 | 11:15 AM
typer_801's Avatar
2490 - no a/c, 1/4 tank of gas.
Old Nov 14, 2001 | 11:18 AM
sackdz's Avatar
Default Re: How much does the US spec ITR weigh? (Mike K)
What kind of diet is your car on mike?
Old Nov 14, 2001 | 01:49 PM
ITR583's Avatar
New User
Yeah Mike,
Talk to me. What'd you do, take out ALL of the seats and ALL of the glass?
You had the wheels ON the car, right?
Old Nov 14, 2001 | 02:11 PM
norice's Avatar
Default Re: How much does the US spec ITR weigh? (ITR583)
The official weight of 2000+ USDM ITRs is 1197 kg (2639 lb). However, most owners who have weighed their 2000+ ITRs have reported numbers in the 1550 lb range. I don't know why there is such a disrepancy.
The increase in weight of USDM over UK/JDM cars can probably be explained by heavier bumpers, side impact beams, AC, and the the dual airbag assemblies.
Old Nov 14, 2001 | 02:13 PM
mr2's Avatar
mr2
Default Re: How much does the US spec ITR weigh? (norice)
http://www.cars.com - research for anything u need
Old Nov 14, 2001 | 03:44 PM
nsxtcjr's Avatar
New User
Yeah, that's a difference of almost 1100 pounds!!!
I bet you meant to say 2550 lb, huh?
Also, USDM weights are usually quoted as curb weight, which means full fluids. Those of you who are quoting actual weights, remember that a full tank of gas contains about 80 pounds of gasoline.
Old Nov 14, 2001 | 03:55 PM
norice's Avatar
Default Re: How much does the US spec ITR weigh? (nsxtcjr)
Yes - I meant 2550 lbs. I didn't realise that a full tank of fuel was quite that heavy. When I weighed my R (on a probably not very accurate town recycling center scale) I got 2520 lbs. I had a close-to-empty tank of gas and no spare tyre or jack (30 lbs) at the time. Now this measurement makes some sense to me.
Old Nov 14, 2001 | 04:01 PM
N1Spec's Avatar
New User
AUSDM spec is quoted at 1079kg without A/C. Hmmm thats around 2400lb..... pretty light eh??
Old Nov 14, 2001 | 04:05 PM
nsxtcjr's Avatar
New User
The tank holds 13.2 gallons. A gallon of gas weighs around 6 pounds.
Old Nov 16, 2001 | 04:27 AM
Mike K's Avatar
Sackdz, ITR583: I pulled the following items out...
Front and rear bumper supports, complete ABS system, complete SRS system, no spare tire, jack, front strut bar, brake dust shields, exhaust tunnel heat shields..
And I replaced the following items for difference in weight..
Traded out stock catalytic for 2.5" test pipe
Traded out stock header for DC JDM stainless 4-1
Traded out P/S system for rack and pinion from a 92 Civic CX
I plan on doing other weight reduction next week. I'll weigh it again and post the results..
I'll be doing the following..
Install my 15x6" Regamasters (car was weighed on stock ITR wheels/tires)
Install RS*R cat-back exhaust (I hope it's a little lighter thn stock)
Install Comptech 6.75lb. flywheel
Install Fastbrakes aluminum hat rotors (less weight on the hat)
We'll see.....
Old Nov 16, 2001 | 05:42 AM
DutchITR1689's Avatar
Default Re: How much does the US spec ITR weigh? (Pillesnoppen)
Hi, I saw 2 ITRs at Sony in Basingstoke (UK) and 1 in London Heathrow airport the last 3 days. Do you know them........ maybe?
Old Nov 16, 2001 | 08:21 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: How much does the US spec ITR weigh? (EuroITR1689)
mine weights 2568
bads2k
Aug 3, 2008 05:57 PM
heel_touge
Apr 16, 2007 08:52 AM
Red_ED8
Sep 26, 2006 08:42 AM
ActiveAero
May 15, 2003 05:29 AM
