Clean 90 CRX HF just bought, check it out! 90 day project soon to happen!!!
I have been looking for another project crx and I found this red 90 crx hf at a used car lot here in WA out in the boonies. I was driving past it to go to a friends house and out of no where there was a small used car lot and sure and be hold there was a 90 crx hf. I looked at it and the exterior paint was immaculate still had the showroom shine to it. All origional! I looked inside and the interior looked brand new black/grey flawless as if it was brand new. Carpet looked brand new. It is an under statement that it was very well taken cared of. It was almost too good to be true! I saved up some money and two weeks later I got her for a song and a dance! 5/28/04. The car will be in a 90 day project I will be doing very soon car will be turned into a very nice sleeeeper! from great gas mileage to shitty gas mileage! Untill then it will get me around from place to place! lol comments? advice?
Picture of it at the lot.
Pictures I took today when I got it home.
Where is the mirror? lol
Coming Soon!
UPDATE:
I got the built bottom last week. The b16 head will be built this week. Transmission already done. Hope to get this project up and rollin soon! Hoping for atleast 175 whp. 9.5-1 comp maybe slightly higher with OEM head gasket. When ready to boost cometic will get it down to 9-1. Redline 8200-8500.
Bottom:
91 B18A1 LS
Darton open deck CRV sleeves, 20 on top
JE 9.2-1 pistons custom, pins, rings
Crower pro billet rods,
Rod and main bearings,
Polished crank,
balanced complete
1 lb alt. only crank pulley
Type R oil pump
GSR water pump
Head: B16
KMS SS valves 1mm intake, .5mm exhaust oversize
Skunk2 valve springs
Skunk2 titanium retainers
ITR cams
Stage 2 PnP
3 angle valve job
ARP head studs
AEM fuel rail
AEM fuel reg.
AEM cam gears
JG manifold
65mm JG TB
Lude injectors
Custom headers 3" collector
Custom 3"-4" exhaust system
Cooling
2”+ all aluminum racing radiator Cool 92-00 civic
Oil cooler
Transmission: 91 LS
PG LSD
ACT 300 lb trq clutch kit
ACT 12 lb. flywheel
P28 obd1 ecu
VAFC
Coming Soon!
UPDATE:
Bottom:
91 B18A1 LS
Polished crank,
balanced complete
Type R oil pump
GSR water pump
Head: B16
ITR cams
Stage 2 PnP
3 angle valve job
ARP head studs
AEM fuel rail
AEM fuel reg.
AEM cam gears
JG manifold
65mm JG TB
Lude injectors
Cooling
Oil cooler
Transmission: 91 LS
PG LSD
ACT 12 lb. flywheel
P28 obd1 ecu
VAFC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phoenixb16aguy »</TD></TR><TR><TD CLASS="quote">only the si's came with both mirror's </TD></TR></TABLE>
This is correct. ONLY the Si's came with both mirrors standard.
On the Hf and Dx, they were dealer installed accessories.
This is correct. ONLY the Si's came with both mirrors standard.On the Hf and Dx, they were dealer installed accessories.
nice house and my 91 hf does come with 2 mirror OEM
______________________________________________
cant wait until the year 2021, cuz tats when 91 CRXz does not require SMOG!!!!
yayayayyayayayayayayayayaayya
B16a2 POWER
B16a2 POWER
Efhatch277
10
Jan 29, 2015 06:03 PM
ExplicitSpeed
Jun 15, 2004 03:32 PM
ExplicitSpeed
Jun 14, 2004 05:38 PM
Buzzbomb
Jun 1, 2004 10:05 AM
