Is a compression test on a motor 100% way to know if you have internal damage?
Old Jun 14, 2004 | 02:41 PM
typeeg's Avatar
Default Is a compression test on a motor 100% way to know if you have internal damage?
Is there any possiblity that there is something else wrong with the engine even if you are getting good numbers throughout?
Old Jun 14, 2004 | 02:54 PM
Chiovnidca's Avatar
Default Re: Is a compression test on a motor 100% way to know if you have internal damage? (StockEG9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockEG9 &raquo;</TD></TR><TR><TD CLASS="quote">Is there any possiblity that there is something else wrong with the engine even if you are getting good numbers throughout?</TD></TR></TABLE>
Yes
Old Jun 14, 2004 | 03:35 PM
typeeg's Avatar
Default Re: Is a compression test on a motor 100% way to know if you have internal damage? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Yes</TD></TR></TABLE>
could you give me some examplese of what things could be wrong that does not show on a compression test?
Old Jun 14, 2004 | 04:18 PM
Bailhatch's Avatar
the bottom 2 rings or ringlands could be damaged and not show up on a comp test. Pretty much anything below the top ring could be in trouble, main bearings, rod bearings whatever...
Old Jun 14, 2004 | 06:06 PM
typeeg's Avatar
Default Re: Is a compression test on a motor 100% way to know if you have internal damage? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">the bottom 2 rings or ringlands could be damaged and not show up on a comp test. Pretty much anything below the top ring could be in trouble, main bearings, rod bearings whatever...</TD></TR></TABLE>
so the only way to know what is wrong internally besides the comp test would be to open it up correct?
Old Jun 14, 2004 | 06:43 PM
Chiovnidca's Avatar
so the only way to know what is wrong internally besides the comp test would be to open it up correct?</TD></TR></TABLE>
It depends on what the problem is.
r1de4life
Jun 10, 2007 04:32 PM
Lucky-13
Apr 10, 2007 01:48 PM
Chubz
Honda S2000
20
May 1, 2006 10:37 AM
DRKSol
Jan 19, 2006 01:18 AM
joostan
Nov 29, 2005 07:01 AM
