gas fume inside my car.
Old Jun 14, 2004 | 02:41 PM
ironchef25's Avatar
Default gas fume inside my car.
help guys.i think i have a problem.. this morning everything was fine.. took my car to the gas station and filled it up before i went to work.. 91 octane ofcourse.. full tank.. drove to my work wich is 25 miles. no prob yet. got off open my car and gas fume just overwhelmed me.. i was like oh shoot.. open all my window an to try to let all the fume out.. after about 5 min fanning inside my car.. decided to drive it home.. now the fume was still there and it was scarry.. had to stick my head out to get some fresh air.. my gas guage was kinna funny though.. it would go down about half way when i step on the gas. got home safely,thank god i didnt pass out..now what the hell is going on my car..i have a b16, didnt have anyproblem untill today.. argh help me out guys..where could that fume be coming from.. also i dont see any leakage when i stop the car and look down.. help pls..
Old Jun 14, 2004 | 02:59 PM
sporkcrx's Avatar
Default Re: gas fume inside my car. (ironchef25)
Definitely sounds like a leak somewhere. Check inside the engine bay first, then check out the lines that run from the tank to the engine bay. I would think the gas lines would be under the car and not inside, but I'm not sure. Definitely something you want to fix though.
Old Jun 14, 2004 | 03:08 PM
mr. carpenter's Avatar
Default Re: gas fume inside my car. (sporkcrx)
if you're smelling it strong inside the car i would check the filler neck, the float, which is under the silver cap, and hoses under the back seat. after that look at the gas tank on the driver's side. there is a plastic cover you'll have to remove and all the hoses go in to the tank there.
Old Jun 15, 2004 | 09:20 AM
ironchef25's Avatar
Default Re: gas fume inside my car. (mr. carpenter)
well its comming just right behind the driver side. the smell is really strong...
Old Jun 15, 2004 | 10:54 AM
that's probably the filler neck leaking. take the seat out and see if you can see any where it's leaking. also look where you put fuel in on the outside. might have a hole there?
Old Jun 15, 2004 | 11:02 AM
Dyn0speed's Avatar
i would 1st check for fuel pressure, if there is a leak then u will aboviously get low pressure. i would definatly check the floater circut, its inside the car. i have b16a2 and my car smells like gas all the time and its normall cuz my ECU is chipped. my car runs rich all the time and tat is my fuel & emission standard. are u sure ur ECU is not chipped!!!
on the fuel filter the 10mm or 12mm service screw remove and hook gauge
floater is under back seat
Modified by Dyn0speed at 3:00 AM 6/17/2004
Old Jun 15, 2004 | 12:55 PM
4drEF's Avatar
Keyboard Humorist
Default Re: gas fume inside my car. (Dyn0speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyn0speed &raquo;</TD></TR><TR><TD CLASS="quote">i have b16a2 and my car smells like gas all the time and its normall cuz my ECU is chipped. my car runs rich all the time and tat is my fuel & emission standard. are u sure ur ECU is not chipped!!! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">...this morning everything was fine.. took my car to the gas station and filled it up before i went to work... </TD></TR></TABLE>
Somebody chipped his ECU at the gas station! I knew it!!!!
Old Jun 15, 2004 | 04:18 PM
ironchef25's Avatar
Default Re: gas fume inside my car. (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
Somebody chipped his ECU at the gas station! I knew it!!!!</TD></TR></TABLE>
lol.. no. its not chipped..how do i check the fuel presure??and wheres the floater circuit
dc4b20
13
Apr 16, 2010 07:01 PM
deerman2701
Mar 1, 2009 08:16 AM
VTEC_Viking
Jul 30, 2008 09:33 AM
1kleenef
10
Oct 22, 2007 06:30 PM
SpoonPL
Jul 11, 2002 06:52 PM
